Powered by Team Mondor
Page 11 of 11 FirstFirst ... 7891011
Results 101 to 109 of 109
Thread: If your looking to put 2JZ cams into your 1JZ, look at this
  1. #101
    Regular Member
    Join Date
    Jul 2011
    Location
    Niagara falls
    Posts
    212
    Default Re: If your looking to put 2JZ cams into your 1JZ, look at this
    Had only enough time to look through the first 6 pages. But is this set up perfectly fine with the stock ecu? Nothing else needed to monitor the bigger lift?
  2. #102
    Regular Member
    525gte's Avatar
    Join Date
    Sep 2011
    Location
    hoquiam
    Posts
    450
    The dude that started this service has not logged on in over a year
    91 bmw 525 I. 1jz swap . Ported head. Cp pistons 9:1 compression. Aem 320pump. Stage 4 Comp clutch and lw fly. Percision 6262 and 46mm wg . 1200cc inj. Ms3pro management . In the process of adding a 2nd fuel pump have swapped to 272s. also going to a 6266 1.0 ....641hp/500trq.... for now
  3. #103
    Regular Member
    525gte's Avatar
    Join Date
    Sep 2011
    Location
    hoquiam
    Posts
    450
    I am not sure but I think this is the part number for the seal that was mentioned TC12549. But I can not locate it anywhere
  4. #104
    Interdimensional
    RacerXJ220's Avatar
    Join Date
    Mar 2005
    Location
    Abalama
    Posts
    1,492
    I think he sold his car, may have gotten out of the game.
    1JZ-GTE, PTE 6466, PGS Dog Box R-154, Pro-EFI 128, HeadGames "R", Hypertune, SP F1, Kelford, E85 and nitrous.
    1983 Toyota Supra.
  5. #105
    Regular Member
    525gte's Avatar
    Join Date
    Sep 2011
    Location
    hoquiam
    Posts
    450
    I am in the process of buying s1 2j cams. I'll try to take pics and post findings on the grinding process. I also have a bearings place down the road I'll go their and see if their is a seal That will work be for we grind the ends
  6. #106
    Supramania Regular
    seoul4korea's Avatar
    Join Date
    Nov 2008
    Location
    Panama City, Florida, United States
    Posts
    589
    Quote Originally Posted by 525gte View Post
    I just did the swap myself not too long ago actually = )
  7. #107
    Regular Member
    525gte's Avatar
    Join Date
    Sep 2011
    Location
    hoquiam
    Posts
    450
    Did you you use the gsc s1 cams? I had to put this project on hold I decided to work out some chassis bugs 1st
  8. #108
    Supramania Regular
    Join Date
    Nov 2008
    Location
    Posts
    589
    I used USDM 2J cams
  9. #109
    All throttle no bottle
    Tgood's Avatar
    Join Date
    Dec 2005
    Location
    ennis/dfw
    Posts
    206
    From what I've heard the lobes on gsc cams are to wide and sit to far forward to fit in a 1jz head
    bpu 91 turbo
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
