Powered by Team Mondor
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Can Royal Purple with LSD additive in R154 cause harder shifts?
  1. #21
    regular member
    Tim's Avatar
    Join Date
    Oct 2006
    Location
    CA
    Posts
    272
    Default Re: Can Royal Purple with LSD additive in R154 cause harder shifts?
    I noticed the same problem with the Royal Purple synthetic when I fist put it into my tranny. The shifts got notchy and slight grinding. I switched over to Pennzoil 80-90 and it shift beautiful now.
  2. #22
    Official SM Expert: Motor Oil, Lubricants & Filtration
    jdub's Avatar
    Join Date
    Feb 2006
    Location
    Valley of the Sun
    Posts
    10,731
    Quote Originally Posted by zoppii
    I take by the first post that this was now RP Syncromax which is made for MT? Has anyone had experience with this stuff?
    From Post #2:
    Quote Originally Posted by jdub
    Synchomax is recommended for manual transmissions that specify automatic transmission fluid, multi-viscosity motor oil or straight grade motor oil...Synchromax is much lower viscosity (less than half at ops temp) than what the TRSM calls for (an 80W-90). Personally, I would not use it in either a W58 or R154...it's simply too thin.
    Not a good idea to use in a Supra tranny...way too thin. Use Red Line MT-90...much better choice if you want to use a syn tranny oil. The Pennzoil 80W-90 Tim is using above is a good choice as well.
    I will no longer respond to tech questions via PM. If you have a question, put it on the forum so everyone benefits from the answer.
    Quote Originally Posted by Supracentral
    However I still stand by my statement that 99 times out of 100, the weak link in the MKIII is the owner.
    Quote Originally Posted by jetjock
    I swear, it's like talking to an amoeba...
    Want to know about oil...read this:
    Motor Oil 101 - Dr AE Haas
    "Life is like a jar of Jalapeno Peppers
    What you do today, might Burn Your Ass Tomorrow"
  3. #23
    Junior Member
    ImperfectSupra's Avatar
    Join Date
    May 2007
    Location
    Virginia Beach
    Posts
    163
    Has anybody use this type of transmission fluid will this work?
    Sent from my SM-N900T using Tapatalk
  4. #24
    jdub's Avatar
    Join Date
    Feb 2006
    Location
    Valley of the Sun
    Posts
    10,731
    Quote Originally Posted by ImperfectSupra View Post
    Pretty sure that contains friction modifiers for an LSD...not good for a R154.
  5. #25
    Junior Member
    Join Date
    May 2007
    Location
    Virginia Beach
    Posts
    163
    Vavoline full synthetic 75 90
  6. #26
    jdub's Avatar
    Join Date
    Feb 2006
    Location
    Valley of the Sun
    Posts
    10,731
    That has zero to do with it....
    Read the rest of the thread.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
