Powered by Team Mondor
Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Archive: MAFT Pro Questions
  1. #1
    Junior Member
    SupraStardom's Avatar
    Join Date
    Nov 2006
    Location
    Council Bluffs, IA
    Posts
    181
    Default Archive: MAFT Pro Questions
    Here's some links to start us off!!!
    drjonez's MAFT Pro FAQ:
    http://www.mkiiitech.com/forums/viewtopic.php?t=641
    drjonez's MAFT Pro archive (manuals, SW updates, etc.):
    http://www.4cefed.com/maftpro/
    How many Maft Pro in MKIII
    http://www.supramania.com/forums/sho...highlight=maft
    Setting up a Maft Pro in AFC mode
    Maft Pro setttings and tuning
    A newbies guide to setting up Maft pro with Tuner Pro Rt
    http://www.mgnta.com/Documents/MAFTProSetup/Setup/
    Maft Pro manual
    http://www.4cefed.com/maftpro/maftpromanual_v1_0.pdf
    Maft Pro Tuning thread
    Maft Pro Install with wiring diagrams for Pre and Post 89 & 89+ HAC Mod
    MAFT-Pro VE Table
    http://www.supramania.com/forums/showthread.php?t=38513
    writeup: MAFT Pro install for 7M-GE
    http://www.supramania.com/forums/showthread.php?t=35302
    MAFT Pro - N/A install - Translator Mode BEWARE- good bit of bad info in this thread
    http://www.supramania.com/forums/showthread.php?t=31806
    MAFT running..Now just needs tuning
    http://www.supramania.com/forums/showthread.php?t=34451
    Gain Adjustment Worksheets - SAFR, SAFC I, II & NEO, MAFT Pro & GenII ◊
    http://www.supramania.com/forums/showthread.php?t=27784
    Maft pro question
    http://www.supramania.com/forums/showthread.php?t=33467
    I just carried these over from the suggestion box
    partially edited by drjonez
  2. #2
    Viking
    StefanLarsson's Avatar
    Join Date
    Jun 2006
    Location
    Sweden
    Posts
    47
    Default Charging System Voltage Too Low: MAFT pro LCD backlight comes on, unit unresponsive
    If your MAFT pro LCD backlight comes on and nothing else happens and the unit seems dead, check your system voltage...
    Your car's battery might be discharged, the MAFT Pro requires at least 10V.
    /Stefan, Sweden
    -91 T, 3" exhaust, 3" DP, single race cat, open air filter, MAFT-Pro speed density, custom IC spray. Upper and lower hardpipes w. SSQV copy.
  3. #3
    thread killer
    pimptrizkit's Avatar
    Join Date
    Dec 2005
    Location
    vancouver Wa
    Posts
    1,573
    Default installing tips!
    Hey guys let's get this section started!
    I figured if we all put in on things we found helped while installing,
    I'll start,
    I found that the check engine light came on for codes 24 and 34 i believe, an air temp and hac sensor?
    Well, I found that the maft pro was not powering up in time for the tccs to do its system check with it wired to power on using the b+ or B on the ecu, I switched the power supply to the cigerette lighter power source (i removed my cig lighter and installed a boost gauge), and have it powering on when the ignition switch turns to the acc position, I also have the wide band doing the same thing to cut down time for it to come online.
    The next thing I found refers more to ANY wiring you do, but for fuel managment it is a MUST in my eyes now, I will not install another with out doing this! SOLDER!
    I have used crimp conections, scotch clips, snap connections, you name it! Each time I pulled my motor I pulled my harness though the firewall, and after doing this several times it has created loose connections (you say your not pulling your motor?), well these connections can be improperly installed I.E. Bad connection, or they can loosen up on there own after awhile.
    The best way to install the conections is to seperate the insulation on the wire enough to wrap the maft pro wire around it. Heat using the iron from the under side, and apply solder from the top of the wire, do not touch their on to add the solder, you want the solder to soak into the hot wire, and not puddle on top of the wire.
    Make sure to use the correct solder! DO NOT use plumbing solde (acid core), use resin core.
    tip from friend
    My preference is "silver solder" for wires... and it is available in Rosin and Acid core, as well.
    partially edited by dr.j
    ~~~MoDs~~~~
    full 3inch w/cat soon test pipe meganR GT turbo muffler~2 peice, 2.5" hard pipes~maft pro-speed density~lc-1 wide band~walbro~255lph~3.93 lsd swap~5spd swap~arp's w/ titian 1.4mm mhg~85ft/lbs~stock ct-26--13psi@ 325whp/318ftlbs
  4. #4
    TRACKMKIII's Avatar
    Join Date
    Feb 2006
    Location
    Atlanta,GA
    Posts
    464
    Default Maf-t Pro and stock setup
    My Na-T set up is almost complete and I have a Maf-t pro on the way. I am wondering if I will see any gains after installation of the Maft-pro and dyno time with a stock setup or should I just wait until I have extra mods. What kind of gains should I expect?
  5. #5
    Supramania Regular
    drjonez's Avatar
    Join Date
    Mar 2005
    Location
    the motor city
    Posts
    3,061
    Default Re: Maf-t Pro and stock setup
    you will certainly see some gains using any tuning device on a stock setup. the gains come from both leaning it out a bit and the timing advance that comes from backing down the AFM signal.
    gains vary from car to car....especially in cars as old as ours. look for 5-20 rwhp.
    MKIII Technical Information Depot: www.mkiiitech.com
  6. #6
    Regular Member
    Join Date
    Jul 2005
    Location
    Ontario
    Posts
    238
    Default Re: installing tips!
    +1...I work with electronics on a regular bases. I've designed circuits and autonomous robots and stereo systems and while building them, I trust no other method then soldering and heat shrink. Please don't do it any other way.
  7. #7
    Supramania Regular
    drjonez's Avatar
    Join Date
    Mar 2005
    Location
    the motor city
    Posts
    3,061
    This thread will serve as an archive of all MAFT pro questions asked in this forum. I will leave individual threads up for a few days and then merge them into this thread.
  8. #8
    Regular Member
    sneakypete's Avatar
    Join Date
    Jul 2007
    Location
    Central NJ
    Posts
    1,129
    Default Re: Archive: MAFT Pro Questions
    i recently upgraded to v4.8. after upgrading, i did a reset and put in my base settings. and so far everything has been going smoothly except for a few things.
    1) i have my vf signal hooked up to maftpro via aux1. since i installed the pro, ive been experiencing a wierd issue. when i first start the car, the aux1 gets no reading. even after i warm it up, nothing, 0.00V. my afr are a bit high around 15-16 at idle and the ecu doesnt compensate very well during cruising. if i shut the car off after its warmed up, and start it again, everything is fine and i get a vf reading around 2.3-2.4V. anyone else having this problem.
    2) about 2 days ago my vf signal started reading a little higher than usual (after i restart the car when it warms up). it used to stay around 2.3-2.4. all of a sudden its around 3.2 at idle, and goes up to 4.43 once i start driving. and it stays pegged 4.43 even after i stop driving. now my afr at idle is around 13.6 at idle. i havent changed any fuel pressure or settings except boost control. cant seem to figure out what happened to change this.
    3) does anyone know where to get a quick start guide for v4.8. i know the settings are similar to v4.4 but there are a few other features that im not familiar with.
    4)and finally, in tunerpro, i dont know how to create a new bin file. or where to get a bin file for v4.8.
    any help would be great. ive been searching everywhere for some answers but have come up with nothing. i am trying to get these kinks ironed out before the etown meet this saturday.
    thanks a lot
    -pete
  9. #9
    workin' my dream
    ilikebigbutts's Avatar
    Join Date
    Jun 2007
    Location
    Pittsburgh
    Posts
    347
    links dont work can someone fix them?
  10. #10
    7M-GE + MAFT Pro + T = :D
    CRE's Avatar
    Join Date
    Oct 2005
    Location
    Denver, CO
    Posts
    3,485
    Still some broken links:
    "Maft Pro Install with wiring diagrams for Pre and Post 89 & 89+ HAC Mod
    http://www.supramania.com/forums/sho...highlight=maft"
    And I need to find the HAC mod... ugh.
    I like an escalator because an escalator can never break, it can only become stairs. There would never be an escalator temporarily out of order sign, only an escalator temporarily stairs. Sorry for the convenience.
    -- Mitch Hedberg
    Quote Originally Posted by IJ.
    Quote Originally Posted by SupraMario
    Fuck the hatters ian...
    You don't like Hats??
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
