Powered by Team Mondor
Page 18 of 27 FirstFirst ... 8141516171819202122 ... LastLast
Results 171 to 180 of 270
Thread: Help! Supra doesn't run right
  1. #171
    Junior Member
    Abe's 1987's Avatar
    Join Date
    Sep 2017
    Location
    Houston,TX
    Posts
    168
    Default Re: Help! Supra doesn't run right
    Quote Originally Posted by 3p141592654 View Post
    They have different part numbers. I don't know what the actual differences are. For the time being, you could bypass the fpr vsv. It is only used to help with hot starts. If you think it is blocked or bad, bypass it for now and retest your fuel pressures.
    Sounds like a plan. Will have to order a new connection for the pressure tester to test pressure again. Will let you guys know the outcome.
    2007 BMW 328i, daily driver
    1997 Chevrolet Camaro z28 6 speed, fun V8
    1987 Toyota Supra turbo 5 speed, new toy
  2. #172
    90T
    3p141592654's Avatar
    Join Date
    Oct 2005
    Location
    Thousand Oaks, CA
    Posts
    3,731
    Did Antec reply about your broken fitting?
  3. #173
    Junior Member
    Abe's 1987's Avatar
    Join Date
    Sep 2017
    Location
    Houston,TX
    Posts
    168
    No they didnt. I'm going to keep trying with them and order a few different fittings meanwhile just to have in case. I might order another one from actron to install permanently to tap in when ever I need to check fuel pressure while I try to get this broken one handled. Did you leave yours in your fuel line 3p141592654 or do you install it when ever you check pressure?
  4. #174
    Junior Member
    Abe's 1987's Avatar
    Join Date
    Sep 2017
    Location
    Houston,TX
    Posts
    168
    Ok so the vsv I have that is connected to the fpr vac part number is 90910-12032. The one that was connected to the egr vac is for sure jammed and not working but i don't see a part number on that one.
    What is the Cco port for on the check connector? I see it written on the back of the cover but there is no wire going to that port.
    I haven't been able to really crawl under the car to check out the fuel lines or state of everything else under and probably won't be able to until next week.
  5. #175
    90T
    Join Date
    Oct 2005
    Location
    Thousand Oaks, CA
    Posts
    3,731
    EGR VSV is 25860-42010
    FPR VSV is 90910-12024
    I leave my fitting connected. The torque spec is only 13 ft-lbs. Not very much.
  6. #176
    Junior Member
    Abe's 1987's Avatar
    Join Date
    Sep 2017
    Location
    Houston,TX
    Posts
    168
    So what is the vsv I have for if it is not for the egr or fpr?
    And wow only 13 ft-lbs? Seems a bit low.
  7. #177
    90T
    Join Date
    Oct 2005
    Location
    Thousand Oaks, CA
    Posts
    3,731
    I'm not a parts expert. But usually the last two digits of a Toyota part number are the revision number. So you probably just have a newer version of the correct part.
  8. #178
    Junior Member
    Abe's 1987's Avatar
    Join Date
    Sep 2017
    Location
    Houston,TX
    Posts
    168
    Got it. Actually makes since as I was even looking at different part numbers for the afm. It was off by one number.
  9. #179
    Junior Member
    Abe's 1987's Avatar
    Join Date
    Sep 2017
    Location
    Houston,TX
    Posts
    168
    Ok so I had gone out of town this weekend and came back to find out something has completely drained my battery. I know for sure all light were off and key was not in ignition and ignition is in the off position. When i left Friday volts were at 12.2 and I checked today Tuesday with volts reading at 1.5. Now i need to figure out what is draining my battery. What can be running without the key in the ignition?
  10. #180
    Far From Maddening Crowds
    Piratetip's Avatar
    Join Date
    Dec 2005
    Location
    MKE, WI
    Posts
    1,020
    Could be a ton of different things.
    Connect an ammeter in series on the negative battery terminal so all the current is going through the meter.
    Do not turn on any lights or other high current components or you may blow the 10A fuse usually in multimeters.
    Trick the hood sensor that its closed.
    Fully turn off the vehicle and lock / enable security system (if it has it), everything you would normally do to leave the vehicle.
    Get a baseline amperage reading once the vehicle has fully shut off.
    Start pulling individual fuses to see which one(s) drop the amperage significantly.
    Once you find a circuit that might be the culprit you can continue diagnosing it further.
    Would also suggest checking stray current discharge going into the coolant system, this is usually caused by bad grounding / on engine / vehicle ect..
    Can also lead to galvanic corrosion on internal coolant system components.
    TIP:
    Vehicles should have a quiescent or key off load of approximately 10 - 60 milliamps.
    Most vehicles are ~ 20mA
    (That's 0.020A)
    Anything higher and you have too much draw somewhere and should be fixed.
    I rebuild / upgrade Supra Differentials - PM me for more information.
    1 Piece Driveshaft Information
    Critical Speed Calculator
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
