Powered by Team Mondor
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: injection issue 7mge need guru help.
  1. #21
    Established 1994
    Nick M's Avatar
    Join Date
    Sep 2005
    Location
    Posts
    8,771
    Default Re: injection issue 7mge need guru help.
    The signal to the injector is ground. If you have power, and the injector is good, you don't have ground.
    Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
    www.thereligionofpeace.com <------- stay in the know, religion drives political beliefs
  2. #22
    Lurker
    Join Date
    Jul 2016
    Location
    Iowa, southwest
    Posts
    21
    Quote Originally Posted by Nick M View Post
    The noid light should confirm this or confirm I fixed the wiring. Either way I want the car done so my son can drive this has gone on long enough.
  3. #23
    Lurker
    Join Date
    Jul 2016
    Location
    Iowa, southwest
    Posts
    21
    the noid connector confirmed that I am getting a ground pulse to #5. I pulled #6 to compare it to a good circuit. I noticed the engine did not run any worse. the pulse was the same. unfortunately it means that cylinder 5 and 6 are not working. I verified that get spark and they are getting pulse.
    I bought one of the little cameras you can connect to your phone and tried to put it in the cylinder then tried to pulse the injector. it didn't work because I was not able to put a been in the end small enough to work it past the intake valve where it gets sprayed.
    I had replaced the injector on 5 with no change. The only option I see left is to replace the injector on 5 and 6 and I am will to shell out $80 for rebuilt injectors. I am just not sure if it will fix it. What do you think?
    question Is there a chance since it is to injectors that there is a problem with fuel pressure? I have replaced the fuel pump and filter. Could the fuel pressure regulator cause this?
    thanks for helping
  4. #24
    Lurker
    Join Date
    Jul 2016
    Location
    Iowa, southwest
    Posts
    21
    Car is fixed injectors replaced
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
