Powered by Team Mondor
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Climate control modules between model years
  1. #11
    What was that noise?
    AFQC's Avatar
    Join Date
    Mar 2008
    Location
    Vancouver WA
    Posts
    57
    Default Re: Climate control modules between model years
    Quote Originally Posted by AbsoluteSpeed View Post
    http://www.cygnusx1.net/Supra/Librar...spx?F=8712&P=1
    It is located under the dash on the passenger side and is mounted on the blower box it self. It is labeled 87138 on that picture and the part number is 87138-24030
    Thanks! None of the parts houses around town have it in stock but should have one here by the end of the week.
  2. #12
    Supramania Regular
    supraguy@aol's Avatar
    Join Date
    Dec 2005
    Location
    Atlanta
    Posts
    4,173
    Its literally one screw, and one electrical plug, and no panels have to be removed.
    It may be the easiest fix you'll ever do to a Supra.
    My Over-budget, Over-deadline build: http://www.supramania.com/forums/sho...-come!-Stage-1... It now runs!
    Project: Lexx- 1988 Targa 5spd.
    NA-GTE swap, Megan EZ Street coilovers, ST swaybars, custom endlinks, Energy Suspension bushings, 18x9/18x10 FR500's, ECU masters DET3, Denso direct-fit 680cc injectors on a brand new oem harness, Aeromotive Stealth pump, Driftmotion IC/ hardpipe setup, Kamainari whaletail, 3in. Magnaflow/Borla exhaust, chromoly flywheel, Spec 2+ clutch, aluminum driveshaft, Wiseco pistons, Cunningham rods, full flow oil cooling setup, Cometic 2mm HG, ATI super damper, ARP head, rod, main and flywheel fasteners, HKS style exhaust manifold, Precision 6266 CEA turbo, DG500 COP setup, Fluidyne radiator, GTmat sound deadening, new carpet. Coming soon: New leather, new sound, new paint.
    My under budget, clean & slow build: http://www.supramania.com/forums/sho...RY-short-build
    Daily: Dora- 1989 Targa 5spd.
    7MGTE, mhg and ARP's, aluminum radiator freeflow DP, Apex'i intake, HKS Super Drager exhaust, 18" FR500's, Tanabe GF210 springs, ST swaybars, Illumina 2 TEMS shocks.
    Lexus afm, 560 injectors, Apexi Neo, wideband. Two-tone black/grey tweed interior, Pioneer Bluetooth/ Pandora/ Sirius/XM stereo. So much for keeping it stock.
  3. #13
    AFQC's Avatar
    Join Date
    Mar 2008
    Location
    Vancouver WA
    Posts
    57
    Got the blower resistor installed, fired it up and nothing. Reset the 30 circuit breaker in the pax footwell next to the AC fuse and all is well.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
