Powered by Team Mondor
Results 1 to 6 of 6
Thread: 88 ecu schematics
  1. #1
    Regular Member
    laxboy36's Avatar
    Join Date
    Mar 2010
    Location
    Chesapeake, Virginia
    Posts
    279
    Default 88 ecu schematics
    Hey does anyone know if the 88 ecu schematics are the same as the 89+ ecu. Trying to get my DET3 installed and was wondering if anyone knew if they are different or the same. And if they are different could help me out with the wiring. Thanks
  2. #2
    A HG job took HOW long??
    Join Date
    Mar 2005
    Location
    Victoria, BC, Canada
    Posts
    1,769
    Default Re: 88 ecu schematics
    What do you need help with, for the wiring?
    Did you see this thread? http://www.supramania.com/forums/sho...ner-3-on-7MGTE
    | AEM v1 | FFIM | Stock Turbo | Stock Injectors | 320whp / 360 ft.-lbs. |
    Build Thread
  3. #3
    Established 1994
    Nick M's Avatar
    Join Date
    Sep 2005
    Location
    Posts
    8,771
    They are mostly the same. Mostly and all the way are not the same.
    Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
    www.thereligionofpeace.com <------- stay in the know, religion drives political beliefs
  4. #4
    Regular Member
    laxboy36's Avatar
    Join Date
    Mar 2010
    Location
    Posts
    279
    Yes with the wiring I'm just checking to see if they are the same bc I had a shop try and put it in and they fucked my car up bad
  5. #5
    hvyman's Avatar
    Join Date
    Apr 2007
    Location
    Posts
    12,578
    Can always verify by checking for the same colored wires at the Ecu and on the engine side and then using a ohm meter to verify its the same wire.
    Basically the difference is that the Ecu plugs are different and the 89+ have the hac sensor in the Ecu.
    But a 88 Ecu pin out off google maps should show you everything you need without needing the whol wiring diagram.
  6. #6
    Regular Member
    laxboy36's Avatar
    Join Date
    Mar 2010
    Location
    Posts
    279
    Is this the one?
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
