Powered by Team Mondor
Results 1 to 6 of 6
Thread: 89 GTE Random Starting issue
  1. #1
    I want all the HAm
    cinderMK3's Avatar
    Join Date
    Apr 2015
    Location
    Akron Iowa
    Posts
    131
    Default 89 GTE Random Starting issue
    So long story short, Car was full rebuild went well, looks great runs amazing
    sometimes the car will turn and just not catch. Now I saw to myself ignition..Maybe igniter going or needs rebuilt as well and there is a great thread on opening it up and cleaning connections.
    but here is the thing If its deciding to not catch If I mash the pedal to the floor and crank it, bam there it goes fires right up.
    and when the car is running its flawless. Just goofy and frustrating to start randomly.
    FPR or the Dampener maybe? searched a bunch of threads and I saw heat soak resting pressure stuff but the car will do this randomly hot or cold not after running a while.
    EDIT: crap sorry I put this under GE threads; sorry mods I'm at work and its early :S
  2. #2
    I want all the HAm
    cinderMK3's Avatar
    Join Date
    Apr 2015
    Location
    Akron Iowa
    Posts
    131
    Default Re: 89 GTE Random Starting issue
    UPDATE: had the issue today it started without throttle mash but while idling just shut off and threw a 14. I have found my culprit. Time to rectify
  3. #3
    Supramania Regular
    kotu100's Avatar
    Join Date
    Nov 2006
    Location
    Easton, Ma
    Posts
    1,935
    If the tach doesn't move when cranking it's the CPS.
    Your code 14 leads me to believe its the CPS as well.
  4. #4
    I want all the HAm
    cinderMK3's Avatar
    Join Date
    Apr 2015
    Location
    Akron Iowa
    Posts
    131
    interesting I was checking out the TSRM and it said to take a look at it, I'll test it as well.
    Just picked up an igniter from member here also just in case. never hurts to have spare parts.
    running the test on the igniter today and will move onto the cps too
    I'll keep an eye for another CPS too.
    much appreciated info
    If anyone has more to check into let me know!
  5. #5
    I want all the HAm
    cinderMK3's Avatar
    Join Date
    Apr 2015
    Location
    Akron Iowa
    Posts
    131
    UPDATE: Good call Kotu Got home and Unplugged my CPS and blew out the connector and pressed a little firmer inserting it into the female end. Car fired right up.
    This is after the car wouldn't catch yesterday.
    I will still keep an eye for another CPS and the igniter on the way. having back up's for the electrical will be fantastic.
  6. #6
    Supramania Regular
    kotu100's Avatar
    Join Date
    Nov 2006
    Location
    Easton, Ma
    Posts
    1,935
    Chances are it's the crispy cps wiring that's causing the issue. You could also double check the air gaps against tsrm spec to make sure everything spec's out.
    Glad you got it running again.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
