Powered by Team Mondor
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: What fuel pump or pumps should i get for a 1000BHP+ setup.
  1. #11
    hvyman's Avatar
    Join Date
    Apr 2007
    Location
    Posts
    12,578
    Default Re: What fuel pump or pumps should i get for a 1000BHP+ setup.
    Aeromotivr makes pumps bigger than the a1000.
    A setup with a surge tank would be the most ideal.
  2. #12
    A HG job took HOW long??
    Join Date
    Mar 2005
    Location
    Victoria, BC, Canada
    Posts
    1,769
    | AEM v1 | FFIM | Stock Turbo | Stock Injectors | 320whp / 360 ft.-lbs. |
    Build Thread
  3. #13
    Supramania Regular
    Join Date
    Oct 2010
    Location
    rochester
    Posts
    1,153
    yeah, I thought about that.
    I talked to sumeet today. he said that two 450's WOULD fit in the tank. since i'm dual feeding the rail already, i'll probably do that. probably have to modify the stock sending unit.
  4. #14
    Interdimensional
    RacerXJ220's Avatar
    Join Date
    Mar 2005
    Location
    Abalama
    Posts
    1,492
    Stock filter is not going to really flow what you want, either.
    Look into the longer 10 micron units. With those pumps, a -6 single feed to the rail will definitely flow 1000rwhp worth of fuel. Many people run dual -6 feeds to help regulate the pressure differences, but if the rail is -8 or larger, it shouldn't be a problem.
  5. #15
    Supramania Regular
    Join Date
    Mar 2005
    Location
    Van,B.C.
    Posts
    799
    I was looking at the Fuelab Prodigy Pump which has a built in speed control and is rated up too 1800 efi hp. Not a bad price for what you get, if it's any good. There's also the Kenny Bell Boost a pump which I've heard about but not researched at all which is an inline pump. Here's a link to the Fuelab pump.
    https://m.summitracing.com/parts/fue-42402-5
  6. #16
    Supramania Regular
    Join Date
    Oct 2010
    Location
    rochester
    Posts
    1,153
    well, my car is almost back together, but I still don't know what to do for fuel. I was hoping to go -6 right from the tank to a fuel lab filter, then split it into 2 feeds in the rail.
    I don't think that will get me past 600 on e85. I talked to a reputable shop owner today and he said two 255's would be enough, but from everything I've read here, that's not the case.
    maybe i'll just run pump gas and a meth kit. pretty sure my fuel system will easily support that.
    any suggestions?????
  7. #17
    Interdimensional
    RacerXJ220's Avatar
    Join Date
    Mar 2005
    Location
    Abalama
    Posts
    1,492
    Make the single feed a -8AN, and you'll be fine. You're still planning on 1000whp, eventually?
    Guys are making 700whp on a single 485 pump, e85.
    The fuel filter should be the long one, not the short Aeromotive style.
    I wrote stuff before, but lost the context of your intent. Late night...
    1JZ-GTE, PTE 6466, PGS Dog Box R-154, Pro-EFI 128, HeadGames "R", Hypertune, SP F1, Kelford, E85 and nitrous.
    1983 Toyota Supra.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
