Powered by Team Mondor
Results 1 to 8 of 8
Thread: Needing help with 7mgte electrical issues!!!
  1. #1
    Lurker
    ktothec13's Avatar
    Join Date
    Sep 2014
    Location
    florida
    Posts
    4
    Default Needing help with 7mgte electrical issues!!!
    Need help with 7mgte electrical issues, my 7mgte randomly runs rich burying the wideband to where it just shows dashes, it wont idle without you giving it light throttle and when you give it more then light throttle itll shut off, not like bad maf at around 2500rpm, it's around 1100ish maybe a little more, it just tries to die like you turn the key off, but if you quickly let off the petal it wont completely stall. If you pull the afm signal wire loose it'll run better, it runs like it normally would without the afm hooked up which is better then when its acting up like this, i men its so bad you cant drive over 10-15mph! I have tried different known working afms with no change whatsoever, disconnect tps, only makes a difference in a slight idle change, im at a loss, itll work great for weeks then slowly start acting up worse and worse til its undriveable, and other times itll just randomly instantly go to the point of undriveability.
  2. #2
    creepy-ass cracka
    jetjock's Avatar
    Join Date
    Jul 2005
    Location
    Posts
    9,439
    Default Re: Needing help with 7mgte electrical issues!!!
    You did all that and are still at a loss?
    In memory of Rimma Kiselitsa
  3. #3
    Lurker
    ktothec13's Avatar
    Join Date
    Sep 2014
    Location
    florida
    Posts
    4
    Yea I haven't been able to figure it out! It can run great at times then slowly get worse, or it'll just get bad instantly, there is no consistency to it, maybe some bad wires in the harness?
  4. #4
    Supramania Regular
    kotu100's Avatar
    Join Date
    Nov 2006
    Location
    Easton, Ma
    Posts
    1,935
    Did you check for any codes?
  5. #5
    YotaMD.com author
    suprarx7nut's Avatar
    Join Date
    Nov 2006
    Location
    Arizona
    Posts
    3,703
    Quote Originally Posted by jetjock View Post
    Quote Originally Posted by ktothec13 View Post
    Lol.
    Woosh.
    ktothec: You need to start with some basics. Unplugging random components doesn't help you figure anything out. There's a process to figuring this stuff out. Check for codes being step 1.
  6. #6
    Lurker
    ktothec13's Avatar
    Join Date
    Sep 2014
    Location
    florida
    Posts
    4
    Is there a write up anywhere on how to wire up the check engine light? lol Mine is in a 76 Celica so I don't have the check engine light, but yea I know I really need to get it wired in and check for codes!
  7. #7
    90T
    3p141592654's Avatar
    Join Date
    Oct 2005
    Location
    Thousand Oaks, CA
    Posts
    3,648
    A 194 bulb with one end to 12V is all you need. See the diagram below.
  8. #8
    Lurker
    ktothec13's Avatar
    Join Date
    Sep 2014
    Location
    florida
    Posts
    4
    Awesome! Thank you so much! I shall see what I can do!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
