Powered by Team Mondor
Results 1 to 4 of 4
Thread: R154 problem
  1. #1
    Lurker
    Join Date
    Aug 2011
    Location
    Moscow Mills, MO
    Posts
    Default R154 problem
    Noise in 3rd gear rattles like a son of a bitch no other gear noise is at all rpm I think the bearing for 3rd just shot shit if anyone has had this issue info would be appreciated thanks in advance
  2. #2
    Lurker
    Join Date
    Aug 2011
    Location
    Moscow Mills, MO
    Posts
    Default Re: R154 problem
    Update first and second started to make noise this morning on my way into work
  3. #3
    I want all the HAm
    cinderMK3's Avatar
    Join Date
    Apr 2015
    Location
    Akron Iowa
    Posts
    131
    How wore are your mounts(tranny and engine)? I ask because twist/backlash from the transmission will cause an excess wear on the mating surfaces inside and lead to this eventually.
    just something to check on if you replace or rebuild the gearbox
  4. #4
    Lurker
    Join Date
    Aug 2011
    Location
    Moscow Mills, MO
    Posts
    I haven't decided yet if I'm going to replace or rebuild but I'll get new ones thanks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
