Powered by Team Mondor
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Rear shock "stopper" part interchangability? (48341-14030 and 48341-14040
  1. #11
    Can't Wait to Be King.
    Zumtizzle's Avatar
    Join Date
    Oct 2006
    Location
    Sac-Town, NorCal
    Posts
    2,858
    Default Re: Rear shock "stopper" part interchangability? (48341-14030 and 48341-14040
    Also have the 91-92 on my 90
    Welcome to the Jungle.
  2. #12
    YotaMD.com author
    suprarx7nut's Avatar
    Join Date
    Nov 2006
    Location
    Arizona
    Posts
    3,701
    Neat to see them side by side. The newer version looks very similar to the generic KYB offering. The KYB boot/baffle is plastic though, not rubber. If yours are rubber that's a difference between OEM and the KYB i guess. They otherwise look identical.
    Best pics I can find of the KYB's from my overhaul are on this page: http://yotamd.com/toyota/mk3_supra/shocks_springs7.html
  3. #13
    Regular Member
    loc182's Avatar
    Join Date
    Jul 2013
    Location
    Seattle, Washington
    Posts
    248
    How is this for irony?
    As far as I am concerned the rear bump stops we have been talking about should have been superceded to the newer part number of 48341-14040. The rubber baffle is awesome and the bump stop itself appears no different.
    In the case of the bump stops for the front of the car they did supercede the original part number of 48331-14060 to the newer 48331-14070...
    At first glance, this looks nice, as it has a longer cover for keeping trouble away from the piston of the shock:
    Left is 48331-14070, right is the older 48331-14060.
    However, the hole in the center is only 16mm instead of the expected 19mm:
    It is hard to tell the difference in the pic, sorry!
    (I should have raised the older part so that the holes were the same distance from the camera.)
    After about 30 minutes of trying to get the bump stop to slide down the piston I gave up and cleaned up my originals to reuse. Happily they were in excellent nick, completely unlike the rears.
  4. #14
    90T
    3p141592654's Avatar
    Join Date
    Oct 2005
    Location
    Thousand Oaks, CA
    Posts
    3,644
    Put some dishwashing soap or armor-all in the hole and they will slip on much easier.
  5. #15
    Regular Member
    loc182's Avatar
    Join Date
    Jul 2013
    Location
    Seattle, Washington
    Posts
    248
    Hmm, I had tried a bit of lubrication to no avail. These things were just too tight... I was worried I might break something if I kept at it when I gave up and went back to the originals.
    Both versions of the new rears were perfect and slid right on, not sure why they small holed the fronts
  6. #16
    Supramania Regular
    atmperformance's Avatar
    Join Date
    Sep 2013
    Location
    San jose
    Posts
    764
    I have the koni bump stops for my konis but those KYB bump stops look like the better option with the boot
    WTB Supra hardtop
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
