Powered by Team Mondor
Results 1 to 3 of 3
Thread: Rebuilding 7M found crank to contain runout
  1. #1
    Lurker
    Join Date
    May 2006
    Location
    Corinth, Maine
    Posts
    30
    Default Rebuilding 7M found crank to contain runout
    Hey guys,
    I'm rebuilding my 7mgte and it needs to have the rod journals ground down due to melting a rod bearing. The machine shop found that the crank shaft had runout in it that needs to be fixed. My question is should I have them fix the runout or find a replacement. I have a 7mge with low miles from Japan so should I pull that crank out and see if that is in better shape? Thanks for the help guys.
    Also anyone know of any good machine shops up in Bangor, Maine area? thanks.
  2. #2
    Lurker
    Join Date
    Aug 2015
    Location
    New York
    Posts
    10
    Default Re: Rebuilding 7M found crank to contain runout
    I know if you stick to that idea it'll be much cheaper than having then fix the crank.
  3. #3
    Supramania Regular
    Join Date
    Mar 2005
    Location
    Van,B.C.
    Posts
    799
    I'd have the other crank checked out and use it instead if it's found to be in satisfactory condition. Guys do have their cranks machined and have had success, though I'm not a fan of that unless absolutely necessary from being unable to locate good parts. But since you do have an extra crank jmo I would choose that option first. Good luck!
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
