Powered by Team Mondor
Results 1 to 4 of 4
Thread: GM Swap help
  1. #1
    Junior Member
    Join Date
    Apr 2007
    Location
    Louisiana
    Posts
    112
    Default GM Swap help
    Anyone have a block with crank in it out of a car? I need a measurement from the trans mating surface to crank.
    Basically how far in is the surface the flexplate bolts to from the back of block.
    I have a adapter plate from best trans. I also have a th350 built and ready. I just think I can figure out a way to use a standard gm converter instead of a hybrid.
    www.nautilusperformance.com
    89 toyota supra 67mm Upgrade
  2. #2
    work in progress
    mark1987supra's Avatar
    Join Date
    May 2008
    Location
    Des Moines
    Posts
    74
    Default Re: GM Swap help
    What Engine? There are quite a few different ways to convert from a Toyota straight six engine to a GM Auto tranny.
    1987 7MGTE MK3, SP Built Short Block, 0.020 oversized Wiesco Pistons, Crower Rods, ARP Head Studs, ARP Main Studs, ARP Rod Bolts, BC 272 Cams, BC 1mm Oversized Valves, SP61 Turbo, Knife edged exh. mani., 1200cc Precision Inj., ProEFI standalone with 4" colored control screen, Aeromotive A1000 FPR, Dual 255 Walbros, E85, ETS Intercooler and Hard Pipes, Blitz BOV, Blitz Nur Spec 3" Cat Back, 3" Test Pipe, BIC SP61 Divorcer DP,
  3. #3
    Junior Member
    Join Date
    Apr 2007
    Location
    Louisiana
    Posts
    112
    I have the adaptor plate from best trans. Already have a built TH350. Need to figure out convertor and see if trans clears tunnel.
  4. #4
    Boosted7M
    Join Date
    Apr 2005
    Location
    CAnada
    Posts
    123
    Do you have contact information for best trans ? Im also looking at going th350 and needing adapter plate.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
