Powered by Team Mondor
Page 10 of 10 FirstFirst ... 678910
Results 91 to 95 of 95
Thread: Official CD009 to Mkiii group buy
  1. #91
    Lurker
    Join Date
    Feb 2012
    Location
    Fultondale, AL
    Posts
    7
    Default Re: Official CD009 to Mkiii group buy
    we now have full swap kits for JZ and 7M MK3 supras twin disc and single disc clutches. If your interested please contact me on facebook, instagram or email me at Jason@cbfperformance.net.
  2. #92
    A HG job took HOW long??
    Join Date
    Mar 2005
    Location
    Victoria, BC, Canada
    Posts
    1,801
    what's the price?
    | AEM v1 | FFIM | Stock Turbo | Stock Injectors | 320whp / 360 ft.-lbs. |
    Build Thread
  3. #93
    Lurker
    Join Date
    Feb 2012
    Location
    Fultondale, AL
    Posts
    7
    Here is the full list with the different options for clutches and driveshafts.
    Adapter plate with hardware $550
    Clutch masters twin disc with hardware $2300
    Spec twin disc $1800
    Single disc flywheel $550
    Chromoly driveshaft with adapters $700
    Aluminum driveshaft $550
    Mk3 shifter $380
    Trans mount $30
    Trans crossmember $150
    Pilot bushing adapter with pilot bushing $40
    CSC with TOB $250
    Mk3 cluster conversion $250
    Plus shipping
  4. #94
    l33t M0derat0r (On some other forum) n00blet here however
    Zazzn's Avatar
    Join Date
    Apr 2005
    Location
    Toronto/Bay area
    Posts
    943
    So I talked to Jason here's an update.
    He's using an Auto ring and pinion gear to lower the final drive. Sorced from wier performace its the 3.55 gear set I believe on tubo autos.
    R154 plate adapter allows you use JZ bell hosuing and bolt it to the CD009 after you cut off the original bell hosuing
    The Adapter plate allows you to bolt the orignal bellhosing to a JZ engine without a new bell housing.
    Waiting on answers how the Speedo adapter works for mk3's since they are mechanical
    Waiting on answers regarding flywheel weight as a light flightweel is great for reving but shit for daily driving as you stall alot because of no weight to forgive for bad clutch engagements also generally transmits lots of noice a low RPM 1000-1500 in a low gear.
    87 TT 2JZ-GTE Stock twins
    91 T 60k Miles
    98 SC300 3.5 NA-T
  5. #95
    Supramania Regular
    SupraClaou's Avatar
    Join Date
    Sep 2006
    Location
    Athens,Greece
    Posts
    837
    Any update ? Just curious how it will end up.
    I still think even the later Nissan CD009 edition 6 speed trans should be kept under 700lbs of torque...around 800-900hp depends on the power setup of each car.
    The R154 has been in the global automotive life for exactly 3 decades and has proven it's self as far as power level. A healthy oem stock,properly working,around 100-150k miles, with Redline MT90 juice inside, and the proper clutch kit will hold 650-700lbs of torque....and all that, under the heavy mk3 Supra chassis!
    We all know a performance company used the CD009 6 speed and boosted 1000hp with it...but that's old news for some mk3's with the R154, and to mention some of the 1000hp mk3s had the long stroke big torque 7M engine to boost the 4 digit amount of horsepower. So, don't question the today's price of an old used R transmission which is around $2000+.
    Anyway, I would love to see how the Nissan 6 speed gearbox is gonna move the mk3 tank! Don't forget people that the Z370 chassis with the later more durable CD009 transmission weights 3230lbs around 300lbs lighter than the mk3.
    I went with the V160. I just finished my swap and did it 100% properly and everything works like oem. Of course it reached the $8000 mark with everything.
    $5000 the used V160, $1200 the used HKS triple clutch kit, $600 the JZA80 TT V160/JZA70 TT R154 hybrid customized two piece driveshaft retaining the (new oem) mk3 center bearing and mk4 mid bearing shaft spline, $200 a modified R154 transmission crossmember , and another $1000 for misc. stuff like new clutch hub bearing kit, new V160 shifter, new boot rubbers and leather trim, shifter knob , custom speedometer ODM unit to make the oem mk3 speedometer work properly, and custom exterior hall sensor ring for the ABS sensor, etc. Last , in the making...the lower rear differential 3.5 ring and pinion with a rebuilt LSD and diff in general. And of course we can go 'lower' by increasing the tire/wheel diameter. I think I will reach the 3.2-3.3 mark with my setup..hopefully!
    Best setup would be a V160 with 3.55 rear diff and 285-40/18" , where you can cruise at 3000 rpms in 6th gear with 87mph (139km/h) actual speed,while the speedo gauge will indicate slightly more.
    ''In the end there will be only one car standing.
    Toyota Supra...simply the best""
    R.I.P. Giagia (grandma)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
