Powered by Team Mondor
Results 1 to 2 of 2
Thread: KKK turbo question.
  1. #1
    Join Date
    Apr 2014
    Los Angeles
    Default KKK turbo question.
    So ive had this turbo for quite some time now. I cant seem to find the specifications on the size of it. The turbo it self has 3 serials on it. One on the Compressor housing, one on the bearing housing, and one on the turbine housing.
    Hear are the serials
    Compressor housing
    Serial: 5232 101 50 96 J
    (Right under it)
    15 0032/2531 with a weird symbol then a 9
    The bearing housing serial:
    4LGZ-352C30 22
    83 087 0925
    5232 970 3274
    The turbine housing serial:
    GGG40 N (looks like an H) then 6
    5232 101 6576 I
    If someone can provide me with the specs to this turbo that be great.
    Here are some pictures of the turbo.
  2. #2
    l33t M0derat0r (On some other forum) n00blet here however
    Zazzn's Avatar
    Join Date
    Apr 2005
    Toronto/Bay area
    Default Re: KKK turbo question.
    maybe a k 27
    87 TT 2JZ-GTE Stock twins
    91 T 60k Miles
    98 SC300 3.5 NA-T
Posting Permissions
  • You may not post replies
  • You may not edit your posts
