Powered by Team Mondor
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Resistance when turning over engine.
  1. #11
    Lurker
    TheMechanic253's Avatar
    Join Date
    Aug 2014
    Location
    Puyallup
    Posts
    Default Re: Resistance when turning over engine.
    After the fact meaning after you started it?
    And "will show up" means spinning a bearing right? haha
    If you're not first, you're last!
  2. #12
    Supramania Regular
    Suprapowaz!(2)'s Avatar
    Join Date
    Apr 2006
    Location
    San Antonio, Tx.
    Posts
    2,911
    I just thought of something. What did you set your ring end gap to? Maybe they're too tight and cause a damn good seal, so when you turn the engine over the compression give you stronger resistance than normal. Just a thought.
    TSRM say No.1 ring set between 0.29-0.44mm. No.2 ring 0.25-0.53mm. Oil ring 0.10-0.44mm.
    What did you spec yours out to?
  3. #13
    Lurker
    Join Date
    Aug 2014
    Location
    Puyallup
    Posts
    Well I measured by thousandths of an inch with feeler gauges. I did not file them at all I just measured them in the honed bore of my block. starting with top ring, going down
    Also my cylinder head is not on yet, so there is only resistance, no compression. I plan on removing one rod at a time and turning the engine over until it stops, then checking that assembly. I think I really should gap the rings evenly...
    Such lack of motivation right now.
    Piston 1 .022-.022-.024
    Piston 2 .020-.024-.025
    Piston 3 .020-.022-.022
    Piston 4 .024-.022-.024
    Piston 5 .018-.020-.022
    Piston 6 .028-.024-.025
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
