Powered by Team Mondor
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: ct12 highbrids ?
  1. #21
    Getting back in the game
    YYCSupra's Avatar
    Join Date
    Aug 2014
    Location
    Alberta
    Posts
    130
    Default Re: ct12 highbrids ?
    I'm looking at the BW EFR 7163 (I think that's the model). It's not a very big turbo but should make 550hp on a 1J. Spool will be very stock like too. Hoping to get it this spring but will see how things go.
    Past (some anyway)
    1987 Toyota Supra, Pearl White, Turbo, Targa w/ Burgundy Leather
    1990 Toyota Supra, Black w/ Burgundy Pearl, Turbo, Targa w/ Grey Leather
    1964.5 Ford Mustang
    Present
    1991 Toyota Supra 1JZ Swap, Red w/ Grey Leather
    2003 M3 Convertible Silver w/ two-tone black/grey leather
    2008 Audi Q7 4.2L V8, S-Line, White w/ black leather
  2. #22
    Lurker
    Join Date
    Oct 2013
    Location
    dublin
    Posts
    19
    Yeh that should be cool ! Got to do a few bits over the holidays then get it back up for more dyno time and should see close to 470 hp
  3. #23
    YYCSupra's Avatar
    Join Date
    Aug 2014
    Location
    Alberta
    Posts
    130
    Well I decided to buy some Chinese made CHRAs for the ct12as. Just going to run it for a couple years then go single turbo. These CHRAs are steel turbine wheel so won't have to worry about delamination. I have two sets of twins but both are toast.
    How's your setup working so far?
    Past (some anyway)
    1964.5 Ford Mustang
    Present
  4. #24
    Lurker
    Join Date
    Oct 2013
    Location
    dublin
    Posts
    19
    I see how much were they ? Perfect yes found a boost leak so gained a bit more midrange power too
  5. #25
    YYCSupra's Avatar
    Join Date
    Aug 2014
    Location
    Alberta
    Posts
    130
    They are about $130USD each. How much HP are you running now?
    Past (some anyway)
    1964.5 Ford Mustang
    Present
  6. #26
    Lurker
    Join Date
    Oct 2013
    Location
    dublin
    Posts
    19
    Thats not bad so.it made 418 flywheel hp last dyno but iv made a few changes sinse then and need a retune
  7. #27
    YYCSupra's Avatar
    Join Date
    Aug 2014
    Location
    Alberta
    Posts
    130
    Actually, it's more like $145, I had a closer look. Still pretty reasonable. Was going to cost over $1300 CDN to rebuild them here and that's just to keep the turbo stock and replace to steel turbine wheel.
    Are you running standalone engine management?
    I'm going to use an EBC to run 13ish PSI. I have 3 inch DP so shouldn't be a problem to achieve that psi.
    Past (some anyway)
    1964.5 Ford Mustang
    Present
  8. #28
    Lurker
    Join Date
    Oct 2013
    Location
    dublin
    Posts
    19
    Yeh it's still not a bad price 1ce the last.i got my turbos done in Australia !
    Yes im runing an apexi power fc from a jza80 with a tweeked performance harness.
    Yehs that should be no problem thats what I originally had done b4 i done the hybrids
  9. #29
    Lurker
    Join Date
    Oct 2013
    Location
    dublin
    Posts
    19
    More up dates finally got a map with decent boost and im very happy and thats it for this car for awhile anyway this was achieved at 1.35 bar on pump gas and I think its the limit of the turbos as its choaking at 5600k rpm
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
