Powered by Team Mondor
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Dyno checkp. 770/638 @ 25psi
  1. #1
    Regular Member
    nathaninwa's Avatar
    Join Date
    Jul 2012
    Location
    Aberdeen, WA
    Posts
    377
    Default Dyno checkp. 770/638 @ 25psi
    Made some small changes, went back for a little checkup and made a realization that my turbine housing is to small. My drive pressures are through the roof and we couldnt make any more than just over 25psi out the top.
    So Im going to move from a .84 twinscroll to a 1.0 housing, finally upgrade my 3x12x22 intercooler and move a slightly larger spring in the WG.
    Ill end up regearing the car too. From the old setup I still have the 4.30 setup in there and I have a 4.11 set on the way.
    This thing is a hoot to drive and with the new RA1 rear tires it will stick 20psi in first (thats all it will build) and take all I can give it on the freeway. This rearend setup is really working well..
    Car did 770/638 at 25psi on a 6466
    http://youtu.be/GBtGurmYGPY
    1991 Volvo 940, 2jz swap, T56, 8.8, MS3Pro, 6466, 9-1 Wisecos, sheetmetal intake, 778/636@26psi
  2. #2
    Supramania Regular
    IndigoMKII's Avatar
    Join Date
    May 2011
    Location
    Madison, Virginia
    Posts
    2,181
    Default Re: Dyno checkp. 770/638 @ 25psi
    Well done, 700+ on any setup deserves a pat on the back. It'll be interesting to see how much more you'll get out of a bigger turbine housing.
    1988 white 7MGTE(Current) est 360 rwhp.
    1987 red supra turbo shell(Parts car)
    1983 supra 5mge(Sold)
    2014 Dodge Dart SXT Rallye 2.4
    Driftmotion DP-Driftmotion catback-CT2657 16+ PSI-Greddy profec bspec 2-AEM UEGO-Walbro400-AFPR-560cc/Lex-Driftmotion IC hardpipe-HKS SSQ-Apexi intake-KYB Excel GR2-Hankook Ventus RS3 225/60/16
    In the makings, 62mm turbo setup. See how far I can push it, shooting for minimum 450 rwhp.
  3. #3
    Authorized Vendor
    empera's Avatar
    Join Date
    Mar 2005
    Location
    Philly.
    Posts
    4,554
    fuck i love your car....good job man, keep on squeezing
  4. #4
    Junior Member
    Join Date
    Jan 2014
    Location
    Cherry Hill, NJ
    Posts
    58
    Great numbers!!! I wish I was at that stage of completion
  5. #5
    Regular Member
    nathaninwa's Avatar
    Join Date
    Jul 2012
    Location
    Aberdeen, WA
    Posts
    377
    Thanks. I have done some datalogging, and at 23psu there is 32psi pre intercooler. So a 4 inch ETS core is on the way. My new gears are here and Im going to try a 4 port boost valve instead of the 3 port so I dont have to change my spring.
    Ive been doing some boost congrol testing for megasquirt, a new code in the beta form ribht now, and its very promising in closed loop.
  6. #6
    Regular Member
    Join Date
    Apr 2007
    Location
    Texas
    Posts
    358
    Awesome car! How are you liking the 6466? Im considering moving down to one from a 6765.
  7. #7
    Regular Member
    nathaninwa's Avatar
    Join Date
    Jul 2012
    Location
    Aberdeen, WA
    Posts
    377
    Im not sure I would call it a downgrade. Its a fantastic turbo with lots of great results. On a mildy prepped 2j from FSR they dynoed just over 900whp. Theres a couple graphs on the net with comparible results between the 6266/6466/6766. The 64 spooled like the 62, but hung on power wise like the 67. On the street doing 3rd type dyno pulls, I have logged 31psi by 4200rpm, and that was with the small intercooler and restrictive turbine. On the freeway during a downshift, this thing hits hard and forces a smile on your face!!!
  8. #8
    Regular Member
    Join Date
    Apr 2007
    Location
    Texas
    Posts
    358
    No, I didnt mean it as a downgrade, sorry for the confusion lol. Im wanting a more responsive turbo for street use and the 6466 seems to be the perfect turbo so far
  9. #9
    Regular Member
    nathaninwa's Avatar
    Join Date
    Jul 2012
    Location
    Aberdeen, WA
    Posts
    377
    We went out messin around the other night, for some reason nobody wanted to mess with me, so on the way home I was able to roll up on our group in third gear while datalogging. I didn't stab the gas, but rolled into it fast. Results, 0psi to 23psi (750ish whp) in 1.3 seconds, 52.8mph to 87mph in 2.5 seconds. You wont be disappointed.
    Edit, that 52 to 87 was the roll in pull, by 60mph Im making 20psi, so 60 to 87 is 1.5 seconds.
  10. #10
    Lurker
    Join Date
    Nov 2011
    Location
    State College, Pennsylvania, United States
    Posts
    great numbers at only 25 lbs!
    You should post this car up on http://2JZPOWER.com - i just added the Volvo 940 as a car model
    Joel Grannas
    8.36 @ 175 - Worlds 3rd Fastest 6-Speed Supra
    http://www.2jzpower.com
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
