Powered by Team Mondor
Page 9 of 9 FirstFirst ... 56789
Results 81 to 87 of 87
Thread: The LHD Digidash Bible
  1. #81
    made in Germany
    Silent Deatz's Avatar
    Join Date
    Jul 2006
    Location
    Zurich
    Posts
    95
    Default Re: The LHD Digidash Bible
    Yes you listed it somewhere. I think I will try to get Yazaki connectors.
    Turbo -----------------------------------------------------------------Turbo (DD)
  2. #82
    made in Germany
    Join Date
    Jul 2006
    Location
    Zurich
    Posts
    95
    A buddy of mine have found a very good source for the connectors.
    http://www.easternbeaver.com/Main/El...onnectors.html
    For the digidash you will need the female 090 MT connectors.
    partnumbers:
    12pin: #12P090-MT Female; 18pin: #18P090-MT Female; 20pin: #20P090-MT Female
    I have bought a set and they fit perfectly.
  3. #83
    kind of a lucky dude
    Pyro15D's Avatar
    Join Date
    Aug 2008
    Location
    Whidbey Island, Washington
    Posts
    644
    Sweet! That really helps out. I'm starting to work on another conversion and finding new connectors really makes my life easier.
    My build thread Convert your factory RHD digidash to fit in your LHD MKIII!
    Quote Originally Posted by Faye View Post
    And.... now I understand why your username starts with "Pyro"
  4. #84
    Supramania Regular
    Join Date
    Jul 2007
    Location
    Australia
    Posts
    1,098
    I have a question regarding the external speed signal generator that the speedo cable connects to.
    Can this be directly connected to the standard ECU or does the digital dash modify the signal before sending to the ECU
    I need to feed a speed signal to a standard ECU to keep the auto trans ecu happy but there won't be a standard dash to supply the signal. The digi dash external speed signal generator looked like a promising solution
  5. #85
    Pyro15D's Avatar
    Join Date
    Aug 2008
    Location
    Posts
    644
    Unfortunately, the digital dash does mess with the signal some before it goes to the ECU. I believe it is something like a divide by 5 setup or something along those lines. The external speed sensor puts out 20 pulses per revolution but if I remember correctly, the stock speed sensor is something like 4 pulses per revolution.
  6. #86
    Lurker
    Join Date
    Sep 2014
    Location
    Ny
    Posts
    Is there anyway to convert the kilometers to standard U.S mph?
  7. #87
    Pyro15D's Avatar
    Join Date
    Aug 2008
    Location
    Posts
    644
    Sorry, I haven't been around here in awhile. Yes there is. I go through the procedures on post #57. I am working on another LHD digidash, but without owning a Supra anymore, it is kind of difficult to experiment around like I did on the genesis project.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
