Powered by Team Mondor
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: 7MGE cylinder head 7MGTE head
  1. #1
    Lurker
    Join Date
    Jan 2014
    Location
    omaha
    Posts
    Default 7MGE cylinder head 7MGTE head
    Does anyone know if the cam caps from a 7mge head will work on a gte head?
    Sent from my HTC One V using Tapatalk
  2. #2
    Junior Member
    Join Date
    Mar 2012
    Location
    andersonville tn
    Posts
    96
    Default Re: 7MGE cylinder head 7MGTE head
    Hvyman pointed out that theyre line bored to the particular head and shouldnt be swapped between heads
  3. #3
    Lurker
    Join Date
    Jan 2014
    Location
    omaha
    Posts
    Yes, I plan on getting the block line honed
  4. #4
    Junior Member
    Join Date
    Mar 2012
    Location
    andersonville tn
    Posts
    96
    Then you shouldnt have a problem with the caps
  5. #5
    Lurker
    Join Date
    Jan 2014
    Location
    omaha
    Posts
    Awesome, the only cap I was worried about was the number one. It looks like where the seal sits is slightly different.
  6. #6
    Junior Member
    Join Date
    Mar 2012
    Location
    andersonville tn
    Posts
    96
    Not the main caps anyway. I dont know if u can have the head line bored but I wouldnt think so since the bearings for the cams are built in
  7. #7
    Lurker
    Prism11's Avatar
    Join Date
    Apr 2012
    Location
    Reading, Pennsylvania, United States
    Posts
    Quote Originally Posted by jenny89 View Post
    You can line bore the cam saddles, however it may not be a good idea if the head is warped. Torquing the head bolts will flatten the head to the block if it is slightly warped, but if the cam saddles are line honed it will cause the cam bores to bow and pinch the cam when it is torqued down.
    I would have the head straightened first and then have it line honed if you are going to go this route, but I would advise just getting a new cylinder head with the matching caps.
  8. #8
    Junior Member
    Join Date
    Mar 2012
    Location
    andersonville tn
    Posts
    96
    Quote Originally Posted by Prism11 View Post
  9. #9
    Junior Member
    Join Date
    Mar 2012
    Location
    andersonville tn
    Posts
    96
    Sorry I messed up the quote lol. So u can line bore the head and keep the clearances in spec?
  10. #10
    Lurker
    Join Date
    Jan 2014
    Location
    omaha
    Posts
    Awesome, I would totally just buy a new head if the price was right. The head I currently have was rebuilt less than 10k ago. Why when I bought it the guy didn't have the caps is beyond me. I have had it inspected and everything is good. Just trying to get my baby back up and running.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
