Powered by Team Mondor
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 49
Thread: 440s+afpr+ Lexus afm
  1. #31
    Lurker
    Join Date
    Jul 2010
    Location
    hertford
    Posts
    33
    Default Re: 440s+afpr+ Lexus afm
    Not leaning out at all. I also did another mod that has had a lot of debate... did away with the egr valve and made a block plate and she runs great. As a matter of fact just smoked the new gto 6.0 the other day. Some people talk about all the risks, while others test the facts and make it to the moon
  2. #32
    Supramania Regular
    Join Date
    May 2011
    Location
    Lancaster, Ohio, United States
    Posts
    1,015
    Quote Originally Posted by Tony View Post
    Hasn't grenaded for the past four years under 22lbs of boost but my A304e has twice. Lol but that is thanks to a transmission shop who considered me paying for a complete rebuild only consist of replacing the torque converter.
    a304e is a awesome trans
    im just trying to figure out how you raised fuel cut to 22 psi with no afpr or piggyback
    and your only using a narrowband to monitor afr's
    QUESTION: When does the 7mgte require a MHG?
    ANSWER: When being assembled in the Toyota plant!!!
  3. #33
    Junior Member
    Join Date
    Dec 2010
    Location
    Grande Prairie
    Posts
    88
    Tony Im curious how it was decided what resistor to put inline the lex afm doesn't make much sense to just throw one in there and what'll that do?
  4. #34
    Turbo Swapper
    Join Date
    Aug 2007
    Location
    Alberta
    Posts
    1,836
    Stop feeding the troll...
    In theory, there's no difference between theory and practice, but in practice, there is.
  5. #35
    Established 1994
    Nick M's Avatar
    Join Date
    Sep 2005
    Location
    Posts
    8,771
    To answer your original question, i have been running 440 s with the lexus afm for the past 4 years.
    And Steve Irwin swam with crocodiles and sharks all the time. Was there a point to your post?
    a garrett gt 35 turbo and a resistor hooked up to mafs
    The car doesn't have a mass airflow sensor. And a resistor will not change the Hz, which is what the PCM monitors, not the amplitude, or even an non existant analog signal. A resistor might set a code for low voltage. It just depends on how much resistance is in your resistor. And if it was an analog signal, it would read even lower of a signal. Your post if full of fail. Just facts though, right?
    Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
    www.thereligionofpeace.com <------- stay in the know, religion drives political beliefs
  6. #36
    creepy-ass cracka
    jetjock's Avatar
    Join Date
    Jul 2005
    Location
    Posts
    9,439
    Big snike! She's ah big bugga!
  7. #37
    Lurker
    Join Date
    Jul 2010
    Location
    hertford
    Posts
    33
    The resistor is hooked up to the mass air flow which is also together with the air intake temp sensor. It sends a false reading of the air temp to the ecu which thinks its much colder outside which in return sends more fuel to the injectors. Since the lexus afm housing is 25% larger or so it only reads through the sensor and allows more air to pass though undetected. The resistor also helps here sending a false report of metered air to the ecu which allows a higher boost until fuel cut. I can get 24psi out but usually hit fuel cut around that time. Have cut back to around 18 right now
  8. #38
    Supramania Regular
    D.J.T.'s Avatar
    Join Date
    Aug 2010
    Location
    Arkansas, United States
    Posts
    874
    ive personally drove a civic with a legit mugen engine in it.. it has wiseco pistons & eagle rods, aem cam pulleys, rc injectors (size unknown) tial blow off valve, tial wasteage, gt35 turbo, EDELBROCK intake manifold, 5" exhaust.... Slowest turbocharged vehicle i have ever driven, the lag is crazy, when boost hits its way over 25 psi (aftermarket gauge gets buried past 25 psi) & it spools around 5k rpm, 6.5K is the rev limit, shift & here comes the outrageous lag again & guess what? a 16 year old owns it.. He has no idea what to do. some guy traded it for some car the kid had & some cash.. MY POINT IS He has no wideband, no boost controller, NOTHING. His car still runs, hasn't blown up, he can go here & there slowly but surely. Idk WTF is going on but thats crazy. i was sure he'd burn holes through the pistons by now...
  9. #39
    Supramania Regular
    Join Date
    May 2011
    Location
    Posts
    1,015
    wouldnt colder intake temps require less fuel since oxygen is more dense? or am i thinking backwards?
  10. #40
    Lurker
    Join Date
    Jul 2010
    Location
    hertford
    Posts
    33
    You are right about cold air is more dense than warm air but because the air is more dense when its cold, you get more bang for your buck. What i mean is, a cylinder of cold air will have more air in it than a cylinder of the exact same size of hot air. The ecu knows this and when detects colder air, it knows it has to dump more fuel to compensate for it.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
