Powered by Team Mondor
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Options; 1. SURGE or 2. MISS FIRE / STUMBLE
  1. #11
    Ninja's, Think about it..
    johnny's Avatar
    Join Date
    Oct 2008
    Location
    sacramento, ca
    Posts
    25
    Default Re: Options; 1. SURGE or 2. MISS FIRE / STUMBLE
    I disconnected the positive battery cable. Will that reset also?
    I cleaned the IAC previously.
    Johnny
  2. #12
    Official SM Decals
    veedubin's Avatar
    Join Date
    Feb 2007
    Location
    Denver, Pennsylvania, United States
    Posts
    459
    Default
    Quote Originally Posted by johnny View Post
    Sorry I wasn't able to text you, if you're available I should be able to tomorrow.
    Yes disconnecting the batt works to.
    I did forget to ask tho, are you on 2j or 7m electronics? One of my biggest issues (on 7m gte electronics) was I accidentally wired the TPS backwards. It was seeing 5V @ idle. Needless to say it didn't like that too much. Use a DMM to see the voltage going to the ECU. Make sure @ closed throttle its around .5V and at WOT is around 4 - 5V.
    Sent from my LG-P504 using Tapatalk 2
    - 25% Off Supramania T Shirts! - Supramania Branded Items: T Shirts, Sticker, More coming -
    Design 5 Studios - Vinyl Graphics, Customized Apparel, Banners, Signs, Decals, And A Whole Lot More!
    Contact me for information or visit us on Facebook
    My Build Thread - 2JZ GE-T
  3. #13
    Supramania Regular
    Join Date
    Oct 2010
    Location
    rochester
    Posts
    1,153
    since you mentioned the tps voltage, here's one for you. i had an issue with an intermittent high/surging idle. i set my tps at idle to .5 volts, and the problem seems to be gone. the strange part is, it only reads 3.xx volts wide open. i am nowhere near 5 volts. should i swap out the tps?
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
