Powered by Team Mondor
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: how much hp for boring?
  1. #11
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    39,070
    Default Re: how much hp for boring?
    Agreed 100% Mike!
    I managed to find a brand new block but there aren't many left!
  2. #12
    Administrator
    GrimJack's Avatar
    Join Date
    Jan 1970
    Location
    Richmond, BC, Canada
    Posts
    12,556
    Quote Originally Posted by IJ.
    Agreed 100% Mike!
    Dude, I'm surprised that you haven't just built an entirely new Mk3 from scratch yet!
  3. #13
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    39,070
    LOL The Diff is the last stock part in the car but that changes next week !
  4. #14
    Junior Member
    Join Date
    Nov 2005
    Location
    Grosse Pointe, Michigan
    Posts
    162
    *shakes head at IJ* you crazy ass aussie, lol
  5. #15
    NDBoost
    Guest
    toyota should do something like nissan...
    Factory Rebuild/Refurbs on the older z's
    Nissan did something crazy like remove all bolts and wiring etc re-coat redo all bolt holes and bolts and repaint/recoat the chassis as well as fully rebuild the motor..
  6. #16
    SupraMania Shirt Slinger!
    Turbo. Targa. Life.'s Avatar
    Join Date
    Apr 2005
    Location
    O'Fallon, MO
    Posts
    1,709
    if you're trying to achieve more power you're better off stroking it (*giggles*). But I don't even know if anyone makes a stroker kit for the MKIIIs...do they???
    Quote Originally Posted by Boost Lee
    Some 'tard in a Honda tried to race me after I pulled out of the drive thru, I'm like, "good ol' Jalapeno Cheeseburger or 89 Civic Hatchback?"...
    Needless to say, I ate them both alive.
    No longer a SUPRA owner...will have another some day.
    "Objects in mirror are more stable than they appear"
    Paypal=SuperDupra@aol.com
    ~Brandon~
  7. #17
    shaeff is FTMFW!
    supra90turbo's Avatar
    Join Date
    Mar 2005
    Location
    MA, 01440
    Posts
    6,192
    Flatlander does.
    Some good, some bad experiences.
    Overall, not a great idea to stroke a stroker, but when the kit performs, apparently it's amazing.
    Tired of having multiple keys? PM me for re-keying lock cyls
    ------3E5 1990 Turbo Targa - 206 1990 Turbo HT-------
  8. #18
    Living the dream... Kinda
    Supracentral's Avatar
    Join Date
    Jan 1970
    Location
    Woodstock, GA USA
    Posts
    10,569
    Stroking a 7M is definitely not the best idea, and I'll show you why. There are several methods that you can use to determine tensile loads on rods, but the most simple and available to someone with basic mathematic skills is to use mean piston speed.
    This is the average speed the piston travels at static engine rpm. Remember that. As we move through these calculations, realize we are talking about the "average" speed. Meaning that the speeds go much higher.
    Next, we need to know good vs bad.
    The industry "rules of thumb" for mean piston speed are:
    Under 3,500 ft/min = Good reliability
    3,500-4,000 ft/min = Stressful, needs good design
    Over 4,000 ft/min = Very short life
    You will find that auto manufacturers keep the mean piston speed below 3500 ft/min in 99% of their motor designs except for a few rare exotic sports cars. The reason? Reliability & warranty. In a few rare cases, manufacturers cross that line for "special" cars. The Supra (both MKIII & MKIV) fall into this class. But they don't go far over that line. But I digress...
    Determining the mean piston speed is damned simple.
    Stroke and RPM are really all you need to know.
    The formula is Cm = 0.167 x L x N
    Cm = mean piston speed in ft/min
    L = stroke in inches
    N = crankshaft speed in rpm
    Take the stock 7M-GTE with a 3.582" stroke and a 6500 redline.
    At 6500 RPM your stock motor has a Mean Piston Speed of 3880 ft/min. Based upon our chart above, you are already "pushing" it in stock trim.
    In comparison the 2JZ-GTE has a stroke of 3.386". This doesn't sound like much of a difference, but do the math and at the factory redline of 6750 for this motor your mean piston speed is 3816 ft/min. At 6500 RPM it's only 3675 ft/min. Much lower stress at the same RPM.
    As you can see the very slightly shorter stroke on the 2JZ allowed Toyota to raise the redline by 250 RPM, but lower the mean piston speed. Both motors are 3.0 liter, but the design change allowed higher revs with better reliability.
    So now go back to our 7M-GTE and let's throw the Flatlander stroker kit into the mix.
    The Flatlander kit has a 3.833" stroke!!! That's HUGE! Do the math and you come up with an impressive mean piston speed of 4160 ft/min at 6500 RPM. Take a look at our chart above. We are deep into the "very short life" area.
    Now stop and think about how a 4 stroke gasoline engine works. Intake, compression, power, exhaust. That's your four strokes. But which one is going to do the most "damage" to our rods when we take mean piston speed into consideration? Lots of people would guess the "power" stroke. And they would be VERY wrong.
    Think about this. Take our Flatlander stroker motor at 6500 RPM. During the exhaust stroke the piston is traveling upward at an amazing average speed of 4160 ft/min. What is there to stop it at the top of the stroke? The exhaust valves are open, there's no compression. The ONLY thing stopping that piston from slamming into the head is the connecting rod. Think about that. That rod not only has to stop that piston, but change directions and accelerate it downward as well. All of this loading is "tensile" loading. (i.e. - the forces are trying to STRETCH the rod) compressive loads (like during the power stroke) are easy for the rods to handle. Compressive forces are a cake walk for a forged rod. Tensile forces (stretching) is a lot more damaging.
    When looked at in this light, is it worth the couple of extra cubic centimeters of cylinder displacement? Yea, a little more off idle pre-boost torque is there, but it's not worth it in my opinion...
    Now this is all a gross oversimplification (I could [and probably should] write a book on this stuff) there are MANY other factors involved.
    For example, the mass of the pistons. Compare a JE brand piston to it's Ross branded counterpart for the 7MGTE. Ever looked at the weights quoted by each manufacturer? JE forged pistons for the 7M are 293 grams. The Ross model is 357 grams! Which one would you rather have your rods trying to stop from 3880 ft/min? Now I'm not saying that a Ross piston is bad, it's not. But it's a heavy son of a bitch. Imagine that mounted on the top of your stroker rod!
    We haven't even talked about crank angles, pistion accelleration, etc, etc... There's a ton more.
    I had to make myself stop here because I can think of about 5 tangential directions I could go off on from here and I could write multiple pages just on internal motor geometry alone.
    But I guess my overall point is that engine design is a science. And there's a ton of information needed to make intelligent design choices. And in my opinon, a stroker 7M isn't the best bang for the buck.
    Damn - I'm a long winded SOB these days... LOL
    >>I will no longer respond to tech questions via PM. If you have a question, put it on the forum so everyone benefits from the answer.<<
    Mike "Nightmare" Donohue
    "Stupidity is permanent and often fatal, Ignorance is curable with education..." -- Me
    Frequently Asked Supra Questions: Rod Knock - HKS WG Springs - Injector Sizing - What is A/R? - Buy a TSRM - HKS HG FAQ - AFPR - Machinist - Overboring - Vac Diags - Motor Oil - Seafoam - Spark Plugs - Air Filters - V6 vs. I6 - Solder vs. Crimp Connectors - How to make power - Stroker Motors - Unreliable 7M's? - Piston Slap - Home made race fuel - Budgeting a build - Tuning and Vf
    Frequently Asked Forum Questions: What will get you banned? - Posting and you - Ideals - Membership - Usage - BBCode - Smiles - Scammers - How to make thumbnails - History
    Other Bullshit: Global Warming - Global Warming Facts - Religion & Politics - Collectivism -War On Drugs - Founding fathers were Diests - Religion and The Constitution - Size of the Federal Gov't - Canadian Healthcare - Socialists -European opinons of the U.S. - U.S. standard of living - U.S. - the worlds best customer - Modern Education - A Government created problem - Environmentalism is a big problem - Taxes - Socialism death toll - Can't afford healthcare? - I am my own god - Atlas will shrug - Not paying a "fair share"? - Income taxes are not a necessity - How to succeed, a 60 second lesson - How a liberal approaches facts. - Who is responsible for the financial crisis? - You asked for it. - Understanding Women - Understanding Men - Personal question? Answer is probably here. - Why I carry a gun. - Fuck the rich? - US Politics in a nutshell - The one principle that matters - Why anarchy is a fools errand - This is what it feels like to be me. - Living an awesome life - The crash is coming
    Since the beginning of recorded history, which is defined by the invention of writing by the Sumerians around 6,000 years ago, historians have cataloged over 3700 supernatural beings, of which 2870 can be considered deities. I donít believe in 2,870 gods, and you donít believe in 2,869. You're nearly as much of an Atheist as I am.
    Government is a good thing: Through correct principles, I govern myself.
    Public Notice: Contrary to popular belief, I do not consider everybody who disagrees with me to have brain damage. Those who don't have brain damage will be able to explain and justify their points of view in a logically defensible way. That's the way the Rational Discourse game is played. If you don't want to play the Rational Discourse Game, don't expect anybody (least of all me) to take you seriously.
    Quote Originally Posted by jetjock View Post
    If you drive like that on public streets I won't be disappointed if, as long as you were alone, they one day hose you out of a twisted mass of smoking metal into a bucket and melt what's left of your car down into tuna cans.
  9. #19
    Conjurer of Boost
    Dirgle's Avatar
    Join Date
    Mar 2005
    Location
    Pauma Valley, CA
    Posts
    1,675
    A truly wonderful write-up Mike. It's good to see somebody bringing this information here. Long winded? Not really, information like this shouldn't just be skimmed across and turned into cliff notes. The information contained here is important, and people should take the time to read it. And I hope they do. It provides a very good image of the kind of conditions our engines must endure.
    Quote Originally Posted by -The Family Prayer
    "And Shepherds we shall be
    For thee, my Lord, for thee.
    Power hath descended forth from Thy hand
    Our feet may swiftly carry out Thy commands.
    So we shall flow a river forth to Thee
    And teeming with souls shall it ever be.
    In Nomeni Patri Et Fili Spiritus Sancti."
  10. #20
    Supramania Regular
    Join Date
    Jun 2005
    Location
    North Carolina
    Posts
    555
    I actually found that very very informative and interesting but was saddened by it's short-ness. I think you should write a couple of pages of the basics of engine geometry. Very nice
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
