Powered by Team Mondor
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Fuel issue? Timing issue?
  1. #21
    creepy-ass cracka
    jetjock's Avatar
    Join Date
    Jul 2005
    Location
    Posts
    9,439
    Default Re: Fuel issue? Timing issue?
    The point behind checking the MIL before timing is to:
    1) Make sure the system really is in diag mode.
    2) Make sure the IDL contact is closed.
    A problem with either of those will prevent the system from disabling ESA.
    In memory of Rimma Kiselitsa
  2. #22
    Supramania Regular
    Join Date
    Jul 2007
    Location
    Florida
    Posts
    2,419
    Quote Originally Posted by jetjock View Post
    the point behind checking the mil before timing is to:
    1) make sure the system really is in diag mode.
    2) make sure the idl contact is closed.
    A problem with either of those will prevent the system from disabling esa.
    esa??
  3. #23
    creepy-ass cracka
    jetjock's Avatar
    Join Date
    Jul 2005
    Location
    Posts
    9,439
    Electronic Spark Advance...
  4. #24
    Supramania Regular
    Join Date
    Jul 2007
    Location
    Florida
    Posts
    2,419
    Ahh... thanks JJ
  5. #25
    Lurker
    blue7mgte's Avatar
    Join Date
    May 2007
    Location
    austin,texas
    Posts
    45
    so I drove the car in 1st gear , trying not to not boost and it made it all the way up to redline with no issues. boost leak? but ive checked all the hoses, is there a better way to check each hose for leaks?
  6. #26
    Junior Member
    91whitepack's Avatar
    Join Date
    May 2012
    Location
    slidell, louisiana
    Posts
    71
    is your intercooler piping stock? i had a similar issue and it ended up being a small leak in my piping right at the turbo near the hose clamp. Of coarse i didnt figure it out until it became a big leak by the hose clamp and my car wouldnt go over 3k without hitting fuel cut and smokeing like a train. check it all over very carefully
    1991 mk3 supra turbo White package with sunroof. 7m-powered
  7. #27
    Established 1994
    Nick M's Avatar
    Join Date
    Sep 2005
    Location
    Posts
    8,771
    Quote Originally Posted by blue7mgte View Post
    So I have issue, when the motor is in park and I rev my motor is fine, but when I put a load on it and push past 2500ish I get what seems to be a misfire/putting feeling.
    This is fairly typical of incorrect base input to the PCM. Engine timing and airflow set injection and timing. Engine coolant temp, air temp, A/C, are all corrections to the basic calculation. Look for an intake leak before worrying about the airflow meter. However, if you have a K&N or any derivative that uses oil, it will get the LED and mirror wet over time. As well as the photo coupler. That includes not over oiling the filter.
    Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
    www.thereligionofpeace.com <------- stay in the know, religion drives political beliefs
  8. #28
    Lurker
    blue7mgte's Avatar
    Join Date
    May 2007
    Location
    austin,texas
    Posts
    45
    so I'm sitting at work and I'm going over everything, reviewing my motor in my head and i just remembered that there isn't a clamp on the hose that connects the BOV to the accordion hose....could that cause a boost leak type issue?
  9. #29
    Established 1994
    Nick M's Avatar
    Join Date
    Sep 2005
    Location
    Posts
    8,771
    You don't need to be in positive pressure (boost) for that to be a problem. Especially if the non tight hose is loose on the fitting.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
