Powered by Team Mondor
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
Thread: This Is Why A JZ Manifold Cannot Be Used On A 7M
  1. #21
    A HG job took HOW long??
    Join Date
    Mar 2005
    Location
    Victoria, BC, Canada
    Posts
    1,769
    Default Re: This Is Why A JZ Manifold Cannot Be Used On A 7M
    Quote Originally Posted by Nick M View Post
    Another that knows just enough to get himself into trouble. The air is moving not static, and the turbocharger has a heat shield.
    I noticed heat issues when I had the stock intake manifold with metal hardpipes. This was driving around in traffic though, not racing.
    And how much stuff did you take off the car that Toyota put there but didn't really need?
    A bunch of stuff. I run a standalone, and there are no emissions regs here. I've also changed ignition setups, fueling, etc, but kept things like the PCV system, etc. I've modified the car for my goals, just like every member here does.
    You would have a leg to stand on if you knew what you were talking about. There is one benefit, the shorter intercooler pipes. And that was done because the JZ is a gutless wonder down low. If the plenum is bigger and the runners bigger in diameter and shorter in length, then you would have a case. But that isn't the case. You are making the case for front facing, not an improved manifold. By the way, the fastest drag car in the US uses the stock manifold. Ported I would guess.
    I'm not arguing that the stock intake manifold is garbage, I'm stating I think that overall, the engine can be improved on. I would assume that when switching to FFIM you would optimize the design to suit your goals, ie plenum volume, runner diameter/length, throttle body size, etc. Who is the fastest drag car in the US right now? I looked at the 1/4 mile time sticky, but I don't know if that's up to date.
    Hey I got an idea. Take the man hours you spent changing over, then see if my taking 30 minutes to change plugs every 2 years is the same.
    I thought my statement about that would obviously a joke, apparently not, my bad
    | AEM v1 | FFIM | Stock Turbo | Stock Injectors | 320whp / 360 ft.-lbs. |
    Build Thread
  2. #22
    Junior Member
    nofx230's Avatar
    Join Date
    Jan 2012
    Location
    Colorado
    Posts
    132
    so does running the ffim setup allow for a bigger intercooler setup due to the ease of pipe routing? or are kits like the drift motion IC kit and HKS IC kit about the biggest usable intercooler you can stick in there? just wondering because my buddies SRT-4 has and aftermarket IC and its like twice the size of the mk3 supra's. Is there a point where big is just too big for Intercoolers?
  3. #23
    Regular Member
    Mr Bojangles's Avatar
    Join Date
    Feb 2009
    Location
    Madison, WI
    Posts
    269
    Well think of your charge system like a plastic bag. The bigger the bag the more air it takes to fill it to target pressure. But they fill pretty damn quick so the difference in spool time is minimal based on intercooler size.
    Quote Originally Posted by te72 View Post
    most people around here would be too busy trying to figure out how to stuff creamed corn through a carburetor to really appreciate E85.
    1990 MKIII 2JZ in process
    1988 MKIII n/a winter warrior
    2010 Challenger R/T Heritage
    2006 V-star classic 1100
  4. #24
    Junior Member
    nofx230's Avatar
    Join Date
    Jan 2012
    Location
    Colorado
    Posts
    132
    yeah that makes sense, are there any bigger intercooler kits other than the drift motion or HKS kits or would i be better off piecing together my own set up? how much bigger can you go on intercoolers in our mk3's
  5. #25
    Regular Member
    Join Date
    Feb 2009
    Location
    Madison, WI
    Posts
    269
    You can go as big as you want to cut your car for, but the 3 inch DM cooler is going to be plenty. If you're really worried about your IAT's then you should consider meth or E85.
  6. #26
    Junior Member
    nofx230's Avatar
    Join Date
    Jan 2012
    Location
    Colorado
    Posts
    132
    Quote Originally Posted by Mr Bojangles View Post
    not really worried just curious, because iv always seen hondas and subarus with intercoolers the size of football fields and wondered why not many people with mk3's run big honking IC's
  7. #27
    Regular Member
    Join Date
    Feb 2009
    Location
    Madison, WI
    Posts
    269
    Because we are all clearly smarter because we are not modding hondas or subarus haha
  8. #28
    Junior Member
    nofx230's Avatar
    Join Date
    Jan 2012
    Location
    Colorado
    Posts
    132
    yeah i kinda like that idea I'm modding and fixing up a car that wasn't per say mass produced think in 91 they only made a lil over 3000 supras
  9. #29
    Regular Supramaniac
    adampecush's Avatar
    Join Date
    May 2006
    Location
    Edmonton
    Posts
    2,122
    And here's how you make it fit without having to weld the runners up. Made this adapter by hand back in the day when my time was worth a lot less.
  10. #30
    Supramania Regular
    Turbo Habanero's Avatar
    Join Date
    Apr 2009
    Location
    Tucson,AZ
    Posts
    4,231
    I thought about having someone make me a adapter to run one. But then decided it was prob best just to go with a Sleeper designs FFIM but i don't want to get rid of the EGR or ISC
    -Jordan.
    My Personal Instagram @Built1jz and I Created a Page for all Mk3 owners @A70_Addicts
    My build thread Furious 7M owner who gave up JUST CLICK ON IT
    Quote Originally Posted by Dylan JZ View Post
    This one wont have the infamous 'M' for malfunction, so I think he'll be just fine
    Quote Originally Posted by IJ. View Post
    Been replaced with a "J" though
    (for Jordan so it's gonna be a close thing)
    Youtube Account - Turbo habanero's youtube Channel Clicky
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
