Powered by Team Mondor
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
Thread: 1ggte (u) information
  1. #31
    Regular Member
    5uprahboy's Avatar
    Join Date
    Aug 2005
    Location
    Auckland
    Posts
    343
    Default Re: 1ggte(u) information
    Anyone know the piston ring sizes? i.e. 1.2mm, 1.5mm, 4mm? etc etc??
    1:15.4 around Pukekohe
    13.63 @ 169kmph at Meremere
    Fastest MK3 at Suprafest 08
    www.supras.co.nz
    1G-GTE - Stinger 4424, T04B 60-1, Audi wastegate, 440cc injectors - 240rwkw @ 16psi
  2. #32
    Lurker
    Join Date
    Oct 2007
    Location
    bathurst
    Posts
    Starcraft II ^^;;
    SupraOfDoom's Avatar
    Join Date
    Mar 2005
    Location
    Milwaukee, WI
    Posts
    3,351
    I was looking at information about weights of the 1JZ compared to the 1G-GTE on another site, but I'm not sure how legit they are.
    Does this sound about right?
    1JZ-GTE - 477 lbs
    1G-GTE - 385 lbs
    I'm also looking for information on the length of the 2 engines if anyone has this info!
    1987 Toyota Supra Turbo 5 Speed Targa
    WI Supra Owner Thread
  4. #34
    Starcraft II ^^;;
    Join Date
    Mar 2005
    Location
    Milwaukee, WI
    Posts
    3,351
    OK, here is the length as well... now this is coming from just sources on car forums so it may not be right:
    1st gen 1JZ length + weight: 29.5" + 477 lbs
    1G-GTE Length + Weight: 27" + 385 lbs
  5. #35
    SPAWNING AN INTERCEPTOR
    group a supra's Avatar
    Join Date
    May 2005
    Location
    learning to weld :) in the united kingdom
    Posts
    1,667
    if any info is required on these shout up i will do my best to answer as i have done so much research on these with building my 2.2 and having got 3 engines
    www.silverlineracing.com my custom and bespoke parts business in the uk building the fastest roadgoing 1ggte mkiii
  6. #36
    Lurker
    Join Date
    Jul 2008
    Location
    Here
    Posts
    Will the JZA70 disc rotor, anchor plate and caliper be a direct bolt on or do I need to fab some thing to make it fit?
  7. #37
    7M POWAH! ;)
    suprra_girl's Avatar
    Join Date
    Mar 2005
    Location
    Auckland, New Zealand
    Posts
    1,776
    it's an a70, everything bolts up
    ga70 got the big brakes in 1990 whereas the rest of the a70 jap imports got them in 89.
    Quote Originally Posted by Yellow 13
    1JZ isnt even fit to wipe the oil from my 7M's leaky rear seal.
  8. #38
    Join Date
    May 2005
    Location
    Posts
    1,667
    and the european cars always had them
  9. #39
    Lurker
    Join Date
    Sep 2008
    Location
    alexandria va
    Posts
    14
    anyone know where I could buy this motor in the US?
  10. #40
    Lurker
    Join Date
    Feb 2013
    Location
    new zealand
    Posts
    hi there just wondering are the bushings on a MA70 the same for the GA70
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
