Powered by Team Mondor
Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Coolant system question?
  1. #1
    mod crazy yo!
    modmonster2008's Avatar
    Join Date
    Sep 2008
    Location
    Seattle, WA
    Posts
    1,055
    Default Coolant system question?
    Okay so i pinpointed my radiator to be causing the loss of water, and so i replaced it, it HELPED, then i got a new thermostat and rad cap, i topped the coolant off, drove it around no coolant gushing noise, on the way back home, LOTS of coolant gushing noise. Did the same next day topped off then gushing noise after about 20 mins driving. The coolant overflow bottle seems to be playing around the min and max levels and returns to normal the next morning, but i still have to add coolant maybe about 1/4 cup? My question is, where else could it be leaking, coolant did not have any combustion gases, nor was the heater core leaking, it just loses water after driving a long time, engine oil is the normal color and the exhaust doesnt have white smoke unless i first start it then it goes away, where could it be coming from? there are no visible leaks nor any noises of any coolant spraying. anyone could possibly help me? let me know, thanks!
    edit: after replacing my radiator i did notice the temp gauge never went up past its normal temp, it would use to occasionally go up then back down, now it doesnt...
    Boost Addict
    90' Targa 1.5JZGTE - Project Car
    89 Targa 7MGTE - Project Car
    86.5 Hardtop N/A - Project Car
    91 Targa - Soon to be 2jzgte
    11' Mazda 3 - Daily Driven
  2. #2
    TWINKY
    NTRA08's Avatar
    Join Date
    Jun 2008
    Location
    Conroe, Texas
    Posts
    537
    Default Re: Coolant system question?
    Are you running water or coolant? Coolant has a greater boiling temp than water. What could be happening is the water in your radiator is boiling and creating pressure, too much for the radiator cap to handle, and releasing it into the overflow tank until the high pressure from boiling over is released. OR. You could have a faulty t-stat. If your t-stat isn't opening like it should you will build too much pressure and it will be released into the overflow tank. And then it will open. A while back I had a similar problem. My car kept spilling coolant out the overflow tank and it would overheat. Everyone was saying I had a BHG. Well jdub stepped in and helped me out. He told me to cut the jiggle valve off, as it being removed it would relieve the pressure and open the t-stat. It worked I haven't had a cooling problem since. So I would try that. And see what happens. If you are running straight water replace it with coolant.
    BTW thank you very much jdub
    I'm not insane. You just don't understand
    1987 Supra GTE GONE
    1990 Supra GTE
  3. #3
    Search.
    A. Jay's Avatar
    Join Date
    Jun 2009
    Location
    Bay Area, CA
    Posts
    745
    A little off track, but are you using the stock temp gauge? If so, I want to let you know that it's desgned to not move for a big range (see this post).
    - from my Archos 5 IT
    Searching SupraMania with Google <<<
    My little sister: get off superstupidmania!
    Me: It's supramania.
    Originally Posted by Greek
    Fuck you A. Jay. My Supra has a penguin seatbelted into the back seat. IT WAS MY IDEA FIRST.
    Originally Posted by Supracentral
    If you don't want it pointed out that you are doing asinine things, don't do asinine things.
    Originally Posted by te72
    Takes time to learn to live with your own inherent awesomeness.
  4. #4
    mod crazy yo!
    Join Date
    Sep 2008
    Location
    Seattle, WA
    Posts
    1,055
    As for NTRA08's post, I am running coolant in the system, but i believe since the leak was repaired i have been using more water in the mixture than coolant (3 h20 to 1 coolant) could that be causing the issue? I have a new OEM thermostat already and cut the jiggle valve off. It just seems to be losing a bit of water every day without any visible leaks, the water from the overflow reservoir returns back to the radiator as the tank level gets lower than when it was running i checked the next morning, its just when i open the radiator id have to keep adding a little more water everyday and its just difficult to find the leak when i cant smell coolant, cant see any leaks, and hear any hissing.
    A. Jay: Yes i am using the stock temperature gauge, and if there is an alternative, what could i use? thanks
    Boost Addict
  5. #5
    Regular Member
    SRZMK3's Avatar
    Join Date
    Jan 2010
    Location
    Federal Way, Washington, United States
    Posts
    367
    i hope this isnt the problem for you... but check behind the engine for leaks that metal heater hose that wraps around the engine corrodes,leaks, and you can usually not see it but hear it...
  6. #6
    TWINKY
    NTRA08's Avatar
    Join Date
    Jun 2008
    Location
    Conroe, Texas
    Posts
    537
    SRZMK3 your right. Also the 90 degree 5/8 hose on the pass side that connects to the front main from the pipe on the side of the block. I had mine leaking there and never saw it until I got shot in the face when is burst. Also there are two hoses on your TB and two on your IAC and one on the bottom of your intake. Check those too. Running that much water to coolant might be your problem. Or it might not. At least you got your t-stat out of the way. Did you replace your rad cap?
    ---------- Post added at 02:30 PM ---------- Previous post was at 02:28 PM ----------
    You could also drain your system a little and put a dye in your radiator. Fire up the car at night and check for leaks with a UV black light
    1987 Supra GTE GONE
    1990 Supra GTE
  7. #7
    mod crazy yo!
    Join Date
    Sep 2008
    Location
    Seattle, WA
    Posts
    1,055
    alright i will check the 90 degree hose on the back of the engine bay as well as the metal hose that wraps around the engine block its just weird how i dont see smell or hear anything and i dont see moisture in the car so no way its the heater core. Ive ran full water on other cars before they never had a coolant gurgling noise and yes radiator cap was replaced the same time i did the thermostat and radiator i just dont know where else it could be leaking..
    Boost Addict
  8. #8
    TWINKY
    NTRA08's Avatar
    Join Date
    Jun 2008
    Location
    Conroe, Texas
    Posts
    537
    If all else fails use the dye and a uv black light
    1987 Supra GTE GONE
    1990 Supra GTE
  9. #9
    mod crazy yo!
    Join Date
    Sep 2008
    Location
    Seattle, WA
    Posts
    1,055
    updates, no visible leak has been found but i did notice the water level always dropped after an hour or so, im hoping its not the heater core, not head gasket as the exhaust does not smell like coolant, nor did the cooling system have exhaust gases, i did notice the hose under the dizzy was suppose to be a 90 degree bend that was kinked to sh*t like it was a straight hose forced on there, ill be replacing that tomorrow, re-torquing my head gasket, and if all else fails, then idk what else to do...
    Boost Addict
  10. #10
    mod crazy yo!
    Join Date
    Sep 2008
    Location
    Seattle, WA
    Posts
    1,055
    replaced all heater hoses with new ones, 90 degree bend hoses are new as well, rad hoses are new and clamps are new as well, head gasket is torqued to 85ft lbs, heater valve bypassed, rad is new, cap and thermostat is new, no apparent leaks anywhere, no fogging up windshield inside, where could the water possibly be going still??
    Boost Addict
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
