Powered by Team Mondor
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Installing crank timing pulley woodruff key, oil seals, and pressing balancer on?
  1. #1
    Fastest mk3 GT4 1/4 mile!
    Figit090's Avatar
    Join Date
    Jan 2006
    Location
    Humboldt County
    Posts
    1,834
    Default Installing crank timing pulley woodruff key, oil seals, and pressing balancer on?
    I've done some searching and reading and found some things, but still have these questions.
    I purchased a new woodruff key for the timing belt crank pulley from toyota, and it's a very tight fit, I can only manage to stick 1/3 of one end in by hand in attempt to wiggle or push it down in...I imagine it should be snug but how snug? It fits the pulley just fine, no wiggle but not tight.
    My original woodruff key was damaged because my harmonic balancer's key was too small, (damn P.O.!) and let THAT get damaged...hence the new key. Tips on getting the little thing in would be appreciated
    Also, I know the harmonic dampener is a "light press fit," can I just get it partially on and let the pulley bolt press it on?
    Lastly, I read a post by IJ about putting permatex #4 around the oil seals to help seal them to the block, and I don't know which color/type of sealant #4 is... and I'm guessing any light grease will be ok to lube the inner wall of the seal?
  2. #2
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    39,070
    Default Re: Installing crank timing pulley woodruff key, oil seals, and pressing balancer on?
    Tap the key in with a plastic hammer or a piece of aluminium.
    Big piece of wood on the front of the damper and tap it on with a hammer, I use antiseize.
    #4 is black just like #3 but it sets up hard whereas #3 stays gooey.
  3. #3
    Figit090's Avatar
    Join Date
    Jan 2006
    Location
    Humboldt County
    Posts
    1,834
    Thank you Ian. Much appreciated.
    My power was out yesterday right after I posted this...very aggravating to know there's probably help waiting but not have the means to do anything about it. All I could do was remove my water pump, and wait. lol.
  4. #4
    Aliens.
    CyFi6's Avatar
    Join Date
    Oct 2007
    Location
    Phoenix
    Posts
    2,976
    Just coat the inner lip of the seal with assembly lube so it doesn't burn up when you start up.
  5. #5
    Figit090's Avatar
    Join Date
    Jan 2006
    Location
    Humboldt County
    Posts
    1,834
    I will either do that or use some grease. Either sounds good though, so I'll probably grab the assembly lube since I have such a huge tube of it. Thanks for the suggestion, I even looked at the tube and didn't even think of using it!
  6. #6
    Poodles's Avatar
    Join Date
    Jul 2006
    Location
    Posts
    17,569
    A lot of seals come pre-greased these days as well
    2015 Subaru BRZ Series.Blue, Valenti tails, Michellin Pilot Super Sports, E85 tune
    >>TomTom Custom Supra Icon<<
    [Quin] 6:00 pm: fuck you
    [Quin] 6:00 pm: assholes
    [Canuckrz] 6:01 pm: fuck you and every mall santa that looks like you Quin
    [Quin] 6:01 pm: lol pwnt
    Aliens Cause Global Warming: A Caltech Lecture by Michael Crichton
    Free Toyota Autotech Literature
  7. #7
    Figit090's Avatar
    Join Date
    Jan 2006
    Location
    Humboldt County
    Posts
    1,834
    Yeah the oil punp seal is pre-lubed with red grease.
    I got the key mose of the way in for the timing pulley but the end closer to the engine is sticking up a little bit and I can't tap it in any further. Since the pulley slips almost all the way over the key by hand, could I just tap the pulley on and let it push the key down if it needs to?
  8. #8
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    39,070
    I usually tap the end facing out a little low anyway Fig, the pully will level it out as it goes on.
  9. #9
    Figit090's Avatar
    Join Date
    Jan 2006
    Location
    Humboldt County
    Posts
    1,834
    Thank you so much Ian! savin me lotsa worry about getting in a bind. literally.
  10. #10
    Built 7M
    Join Date
    Jun 2006
    Location
    pa
    Posts
    1,160
    Tighten that crankshaft bolt to 195 Ft lbs.
    http://www.cygnusx1.net/supra/TechTi...ror_codes.aspx
    My Build Thread http://www.supramania.com/forums/showthread.php?t=34229
    7MGTE ,Je pistons .20 over , king main and rod bearings , new oil pump, new aux. shaft bearings , eagle rods, 3mm hks head gasket, arp main ,rods and head bolts and studs, aem cam gears, hks 50mm wastegate, hks longrunner manifold,Percison gt4088 turbo,greddy type s bov, 4x12x24 xs power intercooler, RPS max 3200 clutch kit , new pilot shaft bearing and throwout bearing, New hoses, Cooleeze upper rad pipe, RC 550 fuel injectors, Lexas afm, A-1000 fuel pump,sump in fuel tank, afr, Still needs installed:Ron's long runner FFIM, QT-45, hurst line-loc,Aem-Ems,greddy catch can
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
