Powered by Team Mondor
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: 7mgte tune up
  1. #1
    Lurker
    7mgteNewb's Avatar
    Join Date
    Jan 2010
    Location
    Salt Lake City
    Posts
    Question 7mgte tune up
    Whats up guys. I just barely bought my dream mk III. The previous owner had rebuilt the ct26, and the head with new gaskets, oversized valves, etc. Its blowing white smoke and He mentioned it hasn't been tuned with the new build on it and could be running too rich. the motor knocks at higher rpms. I am new to this motor so I am just looking for tuning suggestions and tips to help me get this motor running like a champ. Thanks again.
  2. #2
    hvyman's Avatar
    Join Date
    Apr 2007
    Location
    Posts
    12,578
    Default Re: 7mgte tune up
    white smoke is not a tuning issue. your either burning coolant or oil.
    how are your valve stem seals? do you leak any coolant?
  3. #3
    Supramania Regular
    dumbo's Avatar
    Join Date
    Jul 2008
    Location
    Albera, Too Far North
    Posts
    1,914
    Coolant.
    Knocking at high RPMs? I would figure this out first.
    Getting old is mandatory, growing up isn't. --- Boostin Since 10/28/08
    13.4at105MPH/14PSI...The smell of cash is easily forgotten when all you smell is rubber.
    Be careful not to step in the bullshit.
  4. #4
    Lurker
    Join Date
    Jan 2010
    Location
    Texas
    Posts
    5
    Quote Originally Posted by 7mgteNewb View Post
    White smoke is a symptom of moisture in the cylinder, typically due to coolant as mentioned. Unless it is a blueish smoke which is oil. You can do a leak down test on each cylinder with air. Open your radiator cap and see if you can see bubbles. If you do, it's a head gasket issue. Running too rich would typically cause you to push black smoke out the tail pipe. And a Knocking a higher RPM's could be from the timing too advanced or not enough fuel to cool the cylinder.
    Does the motor knock only at higher RPM's?
  5. #5
    Regular Member
    Join Date
    Apr 2005
    Location
    Alpharetta, GA
    Posts
    339
    Could also be indicative of blown turbo bearing. Check the axial shaft for excessive play.
  6. #6
    "Yeah! Take the lemons.."
    Bri7man's Avatar
    Join Date
    Jul 2009
    Location
    Torrance, CA
    Posts
    580
    A vid of the knock would be nice.
  7. #7
    Supramania Regular
    Join Date
    Sep 2009
    Location
    colorado
    Posts
    797
    def a vid of the knock noise. about what rpm is it? high rpm is vague. What kind of knock is it? rod, valves, igntion knock? I would personally find out what and where its coming from first along with checking for bhg or bad turbo. If you got a bhg and repair that and still have a knock, than you got more work ahead of ya. best to get it all done in one shot.
  8. #8
    Lurker
    7mgteNewb's Avatar
    Join Date
    Jan 2010
    Location
    Salt Lake City
    Posts
    Im going to take her into the shop later this week, but I started her up today and she idels fine but after about ten minutes the white smoke starts up. When I rev up to 4000 and beyond my engine light turns on.....?
  9. #9
    Junior Member
    Join Date
    Jan 2009
    Location
    Ft. Collins, CO
    Posts
    159
    The engine light could be a separate issue entirely...as people have said white smoke = coolant; also, there are no engine codes that are related to knocking except for code 52 (bad knock sensor), but I'm not sure if that would cause an audible knock in your case. You should still check your codes though, that will give you some more info...
  10. #10
    Regular Member
    aznboik1mva's Avatar
    Join Date
    Aug 2009
    Location
    Manchester,Ct
    Posts
    328
    could b turbo
    Mk3 Pride
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
