Powered by Team Mondor
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Driveline Vibration
  1. #11
    Supramania Regular
    mecevans's Avatar
    Join Date
    Jan 2009
    Location
    M-bay, cali
    Posts
    1,306
    Default Re: Driveline Vibration
    got a new ds from a local for 20 bucks. vibration and clunk are 100% GONE!
    | 7MGE-T | Rebuilt Steel Center W58 | ACT HD 6-Puck | Ford Carrier Bearing | 3.73 LSD | DM DP | MBC @ 12PSI | Cone Filter | HKS D2 Sport Exhaust | Tien SS Coilovers | Energy Bushings | Brembo Rotors | EBC Redstuff | Goodridge Lines | ATE Super Blue |
    [NA-T 7M][CenCalSupras]
    WANTED:
    -Aftermarket radiator
    -3in Metallic Cat
    -Better MBC
  2. #12
    Lurker
    Join Date
    Jan 2010
    Location
    St. Louis
    Posts
    29
    Sounds like the U joints i would definatly start there
  3. #13
    Junior Member
    dsm_tuner260's Avatar
    Join Date
    Nov 2009
    Location
    Fort Wayne, Indiana
    Posts
    138
    i had this problem once right after i did the auto to mt swap i thought it was the carrier bearing for sure i was wrong the ecu i got was bad it was all the same symptoms as a bad driveshaft part but some how turned out to be an ecu. i just had a stroke of genuis to figure that out with out pulling any parts off or looking at any parts. what really told me it wasnt driveshaft related was once i went to go drive it again after it cooled off for couple hours it didnt do it till it warmed up then it did it all over again.
    89 work in progress. still a long way away from complete.
  4. #14
    Lurker
    Join Date
    Jan 2011
    Location
    Dandenong
    Posts
    I had a driveline problem with my car a while ago, large bangs from the driveline whenever loading or unloading it turned out mine was the centre bearing. Cost a bit over 200 to fix.
  5. #15
    Lurker
    Join Date
    Feb 2011
    Location
    California
    Posts
    My 87 NA has the same problem. The mount is busted completely and I can't find an aftermarket Center Bearing and the Toyota Dealership wants $320 for it.
  6. #16
    shadegarage mechanic
    Join Date
    Sep 2010
    Location
    Virginia
    Posts
    25
    same problem here, had a two part shaft in it stock but the center bearing was getting weak so replaced it with a straight steel shaft for added torque now car vibrates very loudly at around 80mph, not bad when cruising at 80 but if you accelerate then it vibrates again. not sure if its the rear bearing, any ideas?
  7. #17
    MR.I GET IT DONE
    70dreams's Avatar
    Join Date
    Jul 2007
    Location
    New York, New York, United States
    Posts
    99
    This sounds like a balance issue , have the shaft rebalanced and check after that .
  8. #18
    Join Date
    Sep 2010
    Location
    Virginia
    Posts
    25
    checking back in with update on that, turns out my new steel shaft wasnt vibrating even though it feels like it was, it was the tires out of balance! try new alignment and balance the tires, then go for a 85mph run and see the difference
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
