Would really like this to be a sticky. Id also like you guys to chime in...
Im thinking of some of the more common parts we all buy for our cars and the part number for them so in case you HAVE to order them from a dealer/parts group by part number you can.
I'll throw out some common parts, and you guys throw out the part numbers.
-Green truck shifter bushing
-Plastic bushing on the end of the shifter nose
-Coil pack harness for the 7mGTE
-Rubber / Neoprene hose that connects the valve cover to block
-Parking brake pads
19518-42020 Coil pack harness for the 7mGTE
12263-42010 Rubber / Neoprene hose that connects the valve cover to block
Parking Brake
46540-14020 Shoe Assy, Parking Brake, front RH Or LH (qty 2)
46590-14020 SHOES, Supra, Rear, Left 1986 - 1990 (qty 1)
46550-14020 SHOES, Supra, Rear, Right 1986 - 1990 (qty 1)
Targa
63251-14061 Front targa seal
63252-14032 Rear targa seal:
62383-14052 Pass side targa seal
62384-14052 Driver side targa seal
09169-14010 Targa tool handle
09168-14010 Targa hex bit
09120-14011 Targa toolbag
63296-14010 Cap, removable roof, front
63297-14010 Cap, removable roof, rear
Lock bezel clips
90468-04124 RH Bezel "Offset" Clip
90468-04126 LH Bezel "Offset" Clip
90468-04125 RH and LH Bezel "Straight" Clip
Wiper inserts
85221-YZZB1 Front LH (85221-YTCB1 - Canada)
85221-YZZA9 Front RH (85221-YTCA9 - Canada)
85221-YZZA9 Rear 86.5-88 (85221-YTCA9 - Canada)
85221-YZZC8 Rear 89-92 (85221-YTCC8 - Canada)
Wiper blades
85220-16540 Front LH (86.5-88)
85220-1A020 Front LH (89-92)
85220-3A050 Front RH
85220-32120 Rear (86.5-88)
85220-16441 Rear (89-92)
Wiper arms
85190-14630 Front LH (86.5-88)
85190-14700 Front LH (89-92)
85210-14250 Front RH (86.5-88)
85210-14270 Front RH (89-92)
85190-14680 Rear (86.5-88 N/A)
85190-14690 Rear (87-88 Turbo)
85190-14731 Rear (89-92)
Wiper blade to arm screws
90099-00955 Front (Qty: 4 -- 2 per side)
90099-00913 Rear (Qty: 2)
Fan Shrouds
16711-42010 Main shroud (86.5-88)
16711-42060 Main shroud (89-92)
16702-42010 Lower (No.2) shroud
Fan Clutch
16210-42040 N/A (86.5-88)
16210-42060 N/A (89-92)
16210-42050 Turbo (87-88)
16210-42070 Turbo (89-92)
Tail Light Gaskets
81554-14580 (Qty: 2)
Trunk Weatherstripping
67881-14110
Trunk Rubber Stops
90541-09047
Upper/Lower Radiator Hoses
16571-42010 Upper
16572-42020 Lower (N/A)
16572-42010 Lower (Turbo)
Turbo Accordian Hose (AFM to Turbo Housing)
17882-42012
Special Clamps
82710-24010 Brown diag box Engine wire clamp (special order from Japan only)
82711-30070 Black intake runner Engine wire clamp
Under Hood Rubber & Gaskets
15100-42021 Pump assy. (oil pump)
13568-42011 Timing belt
90507-18008 Tensioner spring for timing belt
90916-02364-83 P/S belt
99365-21290-83 Fan belt
99364-20920-83 Belt, V (a/c belt?)
12263-42010 Vent hose, intake cam cover to block.
28226-72010 Starter kit (2)
31231-14040 Hub, clutch
16572-42010 Hose, radiator bottom
Engine rebuild / block part numbers
13011-42011 Ring set (stock size rings)
Can someone specify which bearings rod or main?
13204-42010 Bearing se
11704-43010 Bearing se
96411-44000 Plug, tight (1) (maybe freeze plugs)
96412-43500 Plug, expa (1)
11011-43010 Washer set
90387-26001 Collar ?
31410-14193 Cylinder A?
Auto Trans parts
83710-14700 Cable assy, speedo
83770-22120 Adaptor assy, speedo
5-speed conversion for the pressure plate assy.
31231-14040 Hub, clutch release
90201-71001 Washer, plate
90206-72001 Washer, wave
90520-67001 Ring, shaft snap
31264-14040 Spring, clutch
90201-45023 Washer, plate
31470-14050 Cylinder assy, clutch
96152-00450 Ring, snap
28100-45050-84 Starter, reman exhange
90363-12002-77 Bearing, ball (Pilot bearing?)
90363-45012 Bearing, ball. (Throwout bearing?)
R154
33348-35010 R154 1st gear thrustwasher
3110114010 R154 inspection cover
3110214010 R154 inspection cover
3314630020 R154 deflector
R154 Shifter. W58 Also???
33505-35020 Green truck shifter bushing/shifter seat -- green in picture
33548-31010 lower shifter bushing -- blue in picture
33555-22050 lower rubber shift boot
33584-22020 shifter gasket -- red in picture
93381-16012 shifter bolts need 4
Fuel Tank
77169-14020 Gasket, Fuel Sender Gage
77169-14010 Gasket, Fuel Pump Bracket
Accordion hose
12264-42010 Hose, Ventilation, #4 (PCV)
17348-42010 Hose, Air, #2 (For Idle Speed Control Valve)
17342-42040 Hose, Auxiliary Air Valve, #2 (CBV)
Cooling
16401-63010 Radiator cap (big style pre 90)
16401-72090 Radiator cap (small style 90+)
90916-03078 Thermostat
16341-35010 Thermostat gasket
89422-20010 Sensor, water temp
Engine
11101-42030 Head
11401-49596 Block (N/A)
11401-49606 Block (Turbo)
90099-14088 o ring for cam positioning sensor
90250-08120 dowel pin for block
22278-42010 Idle Speed Control Gasket (to surge tank)
25628-42020 EGR flange gasket #1(surge)
25627-42030 EGR flange gasket #2 (head)
22271-42040 gasket for throttle body to surge tank
13568-49015 timing belt
13505-42020 timing belt idler pulley
90311-42003 oil pump drive shaft oil seal
90311-52003 crankshaft front oil seal
90311-35017 camshaft oil seal
12262-42010 pcv hose to TB
12261-42010 pcv hose to cam cover
Turbo
04111-42021 Complete turbo gasket kit
15471-58010 turbo to turbo oil pipe gasket
15473-42010 turbo Oil Outlet gasket #2 to block
16347-42020 turbo to no.1 & no.2 water pipe gasket
90430-12005 Gasket For Turbo Oil Inlet Pipe to block (2)
90430-14235 turbo no.2 coolant pipe to water outlet housing union gaskets (2)
96721-19010 o ring for dipstick
Throttle Position Sensor:
89452-20050 - 01/86 to 10/86 7M-GE (RPL 89452-28030)
89452-14050 - 11/86 to 04/93 7M-GE
89452-20050 - 08/86 to 02/89 7M-GTE (RPL 89452-28030)
89452-14050 - 03/89 to 04/93 7M-GTE
89452-22080 - 1JZ-GTE
Exterior
75331-14120-01 Black 91+ Toyota "T" emblem (Only colour available)
81521-14332 Euro half amber half clear front turn signal
81511-14332 Euro half amber half clear front turn signal
