| Supra Build Up/Gallery Post photos of your car, or keep us up to date on your ongoing project! It all goes here! |
08-06-2007, 05:52 PM
#1
Ich bin gegan alles
Level up: 79%, 74 Points needed |
Spent time on board: 1 Week, 3 Days and 17:33:53 Hours
Complete front end rebuild. Poly bushings
I'd thought I'd share my pain now that the job is finished.
A little background first, I've owned my '91 supra for 6 years now and the front end and steering rack have always given me problems. I had movement in the rack and the DS rack mount and nut broke off and had to be welded back twice. I knew what was coming, a full subframe replacement. I drove it the last two years without being able to keep a proper alignment and tire wear finally drove me to trying to swap and rebuild the entire front end.
This car was wrecked at some point before me and the subframe was not replaced as it should have been.
I bought a used but very straight 89+ subframe for $50
I stripped it down, cleaned and painted everybit of the unit.
This subframe had 103,000 miles on it and was in great condition after clean-up.
08-06-2007, 06:04 PM
#2
Ich bin gegan alles
08-06-2007, 06:20 PM
#3
Ich bin gegan alles
The front subframe bushings were easy to remove, just some good hammering on the metal inner sleeve and a few knocks with a large screwdriver, and they popped harmlessly to the earth
Here they are installed with out the inner sleeves. Much stiffer than stock..night and day actually.
After removing the stock suspension, I made an engine support to hold the engine from crushing my mortaged skull from a 4X6.
This and a tight engine chain with nice hooks held the engine up, while I lowered the subframe. The subframe without the susension is not that heavy.
08-06-2007, 06:22 PM
#4
NA->TER
Level up: 45%, 222 Points needed |
Spent time on board: 2 Days and 7:53:17 Hours
Re: Complete front end rebuild. Poly bushings
Very interesting good pictures also taken this is something I will also be doing to my supra my subframe is bent blah.
08-06-2007, 06:53 PM
#5
Ich bin gegan alles
Here is the subframe installed with one of Ronnie's bushings. What I ended up using as a washer is the stock bushing's bottom cut off and flipped over, as the new washer....perfect fit. This was just a test fit.
Here is the suspension back together and boy does it go together tight. The rebuilt steering rack was the hardest thing to install, everything is very tight with the poly bushings now.
Here's the damage to the subframe DS rack bushing clamp area.
This was really messed up and somebody at a Fresno, CA bodyshop must be killed!
Here is the pile of junk from the swap. Anybody want anything?
The total cost for this rebuild was near $1500.
New parts include.
2 tems Tokico struts,
2 ball joints
2 steering end links
Full poly bushing kit
New strut bump stops
Newly rebuilt power steering rack
new rack boots
used subframe, paint clean and undercoat.
wheel alignment
New tires as the old ones were toast
New steering hose crush washers
This was not an easy job, I have about 24 hours of labor into the swap.
I have the car home from the alignment shop and it drives so nice and tight, it's amazing. I was old enough to test drive a new supra when the A70 was out, but I never did. I suspect that my '91 drives as nice or even better than new, with the improved bushings. Next up in 4 weeks.....5 spd swap. Pedals and master are already installed, rebuilt tranny is waiting for me in WA. state.
Chris D.
Idaho
08-06-2007, 06:55 PM
#6
Points: 95,793, Level: 100 |
Level up: 0%, 0 Points needed |
Chris: Well done!
I agree it's a HORRIBLE job but Ronnies kit will give you great service.
One thing I did do based on past experience is to use Moly Grease in the bushes to prevent squeaks, 4 years on it's still nice and quiet
08-06-2007, 07:15 PM
#7
Ich bin gegan alles
Quote:
Originally Posted by IJ.
Chris: Well done!
I agree it's a HORRIBLE job but Ronnie's kit will give you great service.
Thanks IJ. Ronnie advised me to use moly grease also. I have every moving poly bushing greased and nipped fitted.  No squeaks!
The differance in this car is amazing and I've only driven it 4 miles so far!
CWD
Idaho
08-06-2007, 07:28 PM
#8
Matthew 6:33
Level up: 49%, 204 Points needed |
Spent time on board: 1 Week, 5 Days and 0:45:42 Hours
Very nice, how much are the bushings alone if you dont mind me asking? How come you didnt pull the motor so you could spray the bay black to match the car?
08-06-2007, 07:35 PM
#9
Ich bin gegan alles
Quote:
PM Ronnie in his thread for a price.
Pull the motor just to spray it? Crazy talk.
I like my engine bay red, thank you.
cwd
08-06-2007, 08:51 PM
#10
Regular Supramaniac
Level up: 10%, 361 Points needed |
Spent time on board: 3 Weeks, 3 Days and 7:05:00 Hours
very nice...how difficult was it to remove those front A-arms? (mine are still on my original subframe...probably sitting in some scrap yard somewhere lol)
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
