| 7M-GTE Engine Technical Discussion Have a problem with your 7M-GTE? Technical tip or trick? Post here. |
11-06-2009, 05:59 PM
#1
cure for the common rice
Level up: 69%, 63 Points needed |
Spent time on board: 1 Week, 0 Days and 5:23:47 Hours
Dual bov's
Ok so I've seen the same bov done twice (as in two of them) on the same car, would it b detrimental to my performance to run two different ones for a completely unique sound?
11-06-2009, 06:59 PM
#2
Junior Member
Level up: 68%, 32 Points needed |
Spent time on board: 2 Days and 5:17:40 Hours
Re: Dual bov's
i dont see why not...as long as those bov are doing there correct job it should be fine
11-06-2009, 07:39 PM
#3
Supramania Regular
Level up: 44%, 254 Points needed |
Spent time on board: 2 Months, 1 Week, 2 Days and 2:54:36 Hours
Re: Dual bov's
Other than it being kinda gay it shouldn't cause any problems.
11-06-2009, 07:40 PM
#4
www.atlanticwebgroup.com
Points: 14,012, Level: 51 |
Level up: 39%, 338 Points needed |
Spent time on board: 3 Weeks, 2 Days and 5:46:45 Hours
Re: Dual bov's
Too much air being vented will increase your spool up between shifts. If you do it, use properly sized BOVs.
__________________
There's something about cruising the streets in a highly modified 20+ year old Japanese car, and absolutely raping the newer domestics/imports that I just couldn't replace with a newer car...  - shaeff
1989 Hardtop 5 speed
|4.30 gears|Eibach ProKit|KYB GR2|Megan F&R bars|MKIV 16" wheels|Kumho 225(f) + 245(r)|
|440cc injectors|Walbro Pump|XSpower Mani|XSpower 40mm gate|DM Freddy BOV|XSpower FMIC|Custom 2.5" piping|Custom 3" turbo back decatted|
|Holset HX35w 14cm housing|Apexi SAFCII|Aristo ECU on JZA70 wiring|
Build Thread > http://www.supramania.com/forums/showthread.php?t=44235 < Build Thread
11-06-2009, 07:41 PM
#5
Points: 95,793, Level: 100 |
Level up: 0%, 0 Points needed |
Re: Dual bov's
Keep in mind if you're doing it for noise it's going to be quieter.
11-06-2009, 08:30 PM
#6
Junior Member
Level up: 75%, 38 Points needed |
Spent time on board: 2 Days and 15:23:58 Hours
Re: Dual bov's
I'm no expert, but I'm gonna say 2 would be totally pointless.
-AM3
__________________
Quote:
Originally Posted by gaboonviper85
Doesn't that still happen even with the tsrm way? I thought cussing, wrench throwing, and bleeding hands was the signs of doing it correctly?
I thought that doing it the other way just meant a little louder, little more air time for wrenches, and alot more blood!?
11-06-2009, 09:18 PM
#7
Behind blue eyes...
Points: 32,700, Level: 79 |
Level up: 32%, 550 Points needed |
Spent time on board: 2 Months, 1 Week, 5 Days and 0:45:37 Hours
Re: Dual bov's
Depends entirely on how much boost/flow you have. It's quite common to have more than one on high power cars.
__________________
'89 Turbo Targa 5-Speed, ARP Studs, Cometic HG, Whiteline Adj. Swaybars, ZW DDP, Cooleeze Hardpipes, Apex'i Intake, Type II BOV, Action Stage 3 Clutch, Bilstein Shock & Springs w/ Cusco Mounts, Raptor Racing Exhaust & Cat
>>TomTom Custom Supra Icon<<
Quote:
[Quin] 6:00 pm: fuck you
[Quin] 6:00 pm: assholes
[Canuckrz] 6:01 pm: fuck you and every mall santa that looks like you Quin
[Quin] 6:01 pm: lol pwnt
[Dunckel] 11:55 pm: yeah, we are all dunks, and we all beat our wives, and tase innocent people
[19:20:58] zumtizzle: IJ. is a walmart greater
[19:21:09] zumtizzle: as is Supracentral on tuesdays
11-06-2009, 09:25 PM
#8
The Name's Chunks
Level up: 16%, 338 Points needed |
Spent time on board: 1 Week, 3 Days and 13:27:41 Hours
Re: Dual bov's
Anyone know of a good high flowing recirculation valve? Something like Ians valves would be nice.
Im going to be running meth pre-turbo so i want to route my blow off air somewhere it wont cause an engine bay fire.
__________________
Check out my Build Thread
'89 Turbo Targa *13.8 @ 99.4*
Quote:
Originally Posted by IJ.
Maybe Chevy needs to stop making motors Billy Joe Bubba can pull apart in the trailer park and make some with multivalves and DOHC if they want to play with the big boys
11-06-2009, 09:49 PM
#9
Re: Dual bov's
Quote:
-AM3
Yes agreed you're no expert.....
11-07-2009, 06:39 AM
#10
600 or bust
Level up: 30%, 248 Points needed |
Spent time on board: 2 Weeks, 3 Days and 10:35:41 Hours
Re: Dual bov's
hey IJ what size bovs are those?
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Dual stock BOV
Foti89Supra |
7M-GTE Engine Technical Discussion |
5 |
09-05-2009 05:07 AM |
Dual Exhaust 1JZ
mischief7m |
Other Engine Tech (1JZ-GTE, 2JZ-GTE, Etc) |
11 |
10-01-2008 01:42 AM |
Dual Walbros?
twincam187 |
General MKIII Discussion |
126 |
10-20-2007 07:18 PM |
Dual BOV setup
casper35404 |
4 |
03-01-2007 09:02 AM |
Dual?
87soup |
3 |
03-23-2006 10:15 AM |
