| Supra Racing/Dyno A forum for all racing and dyno discussion. Post your dyno charts or come here for tips, tricks, and techniques that deal with racing your Supra.
All generations. |
10-11-2009, 03:29 AM
#1
Lurker
Level up: 73%, 55 Points needed |
Spent time on board: 8:24:59 Hours
OZ Turbo-A Dyno
Hey Guys
I have a build thread or ride thread here about my car. just got it pretty much back and run in the engine and tuned now. Just thought i would show it around and get peoples opinions, honestly i was expecting more power out of it, whether or not the dyno is reading a little low which is what i hear around down here.
But i know people on the US threads are more pro 7M so wouldnt mind getting some more perspective on it. cheers guys
numbers so far are 410RWHP @ 20psi
mods from memory:
Forged Pistons
worked Rods
Race Bearings
Denso 660cc injectors
Aeromotive FPR
FFIM with q45
Ebay exhaust manifold
Garrett T04Z .86 AR
Tial 44mm W/G
Microtech ltx12s
Individual Bosch Coils
GFB bleed valve
stock head with 7MGE intake cam
Cometic 2mm headgasket
3" Dump/test pipe/HKS 3" system
600x300x100 I/C and custom piping
__________________
'88 Turbo-A
10-12-2009, 04:54 AM
#2
Lurker
Re: OZ Turbo-A Dyno
any opinions or is this about right for what i have done to it?
__________________
'88 Turbo-A
10-12-2009, 05:21 AM
#3
dirty mechanic
Level up: 21%, 239 Points needed |
Spent time on board: 1 Week, 6 Days and 14:53:41 Hours
Re: OZ Turbo-A Dyno
Hi mate, good to see another turbo-a! I notice your running a 7mge intake camshaft, well your mid range is strong to be expected but i believe if you run somthing a little more suitable for your mods you may yield a much stronger top end. The 7mge camshafts are great for low to mid range then just drop off once the revs pick up, it's been discussed a few times on here if you search.
Great work so far and look forward to more updates and details on your beast.
__________________
Turbo-A owner with a boner
10-12-2009, 05:28 AM
#4
dirty mechanic
Re: OZ Turbo-A Dyno
Yikes, i just noticed 20lbs boost with a t04z ....Just as a rough comparison my turbo-a stock internally made 350rwhp with just a map ecu and 550 injectors and a 60-1 at only 14psi boost. My opinion is your figures are low for your mods but every dyno is different so don't stress.!
What was your afr's like?
__________________
10-12-2009, 08:58 AM
#5
rubber slinger
Level up: 50%, 126 Points needed |
Spent time on board: 1 Week, 5 Days and 8:08:34 Hours
Re: OZ Turbo-A Dyno
what kinda torque #? how much timming and what fuel?
have you done a compression test to this engine?
if compression checks out ok then, some different cams and cam gears should hep out a good deal.
10-12-2009, 10:17 AM
#6
Lurker
Re: OZ Turbo-A Dyno
not a compression test yet no, its a newly built motor so havnt really thought of doing it yet.
not sure on torque, didnt get a printout of that will prob have another chat to the tuner when i get a chance.
was on premium pump fuel.
am thinking of trying a mix of premium and race fuel (recommended by Dan - HKS TRD)
and maybe a power run on different dyno to make sure its not just me being paranoid.
i do want to do head work to it, just didnt have the money at the time of the build to do it and if i was gonna put cams in it i would want to do everything while im there. All in due time, but i just know of people making big numbers with less mods then me
cheers guys
__________________
'88 Turbo-A
10-12-2009, 11:54 AM
#7
needs his car done
Level up: 20%, 242 Points needed |
Spent time on board: 4 Weeks, 0 Days and 5:12:49 Hours
Re: OZ Turbo-A Dyno
get a turbo intake cam.
10-13-2009, 09:21 AM
#8
Lurker
Re: OZ Turbo-A Dyno
mmm ok cool, i might look into a normal cam again or if i can find some decent performance cams for it. then give it another shot with some better fuel. cheers guys
__________________
'88 Turbo-A
10-13-2009, 12:10 PM
#9
I heart SM
Level up: 46%, 109 Points needed |
Spent time on board: 1 Week, 0 Days and 17:23:39 Hours
Re: OZ Turbo-A Dyno
Nice numbers for a dyno dynamics dyno
-cheers
__________________
02 IS300 "2j power"
89 Supra "7m power" - Its getting more money thrown at it than Jessica Alba would if she were a stripper.
10-13-2009, 04:39 PM
#10
dirty mechanic
Re: OZ Turbo-A Dyno
I have a pair out of a turbo-a if you want them for $50.00.The cam lobes are the same profile as a normal 7mgte but unsure as to whether there is any difference in duration (should be just the same as stock).
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
