SupraMania
Go Back   SupraMania > Articles > J. Seaman's Guides
Notices
J. Seaman's Guides This forum is for posting articles and answers to frequently asked questions, and is not the place to ask for information, if you need more information on a specific subject, simply ask in the General forum.
Reply
Article Tools Display Modes
Old
JSeaman's Avatar
JSeaman JSeaman is offline
SM Official Expert: Guide Author
Points: 1,446, Level: 15
Points: 1,446, Level: 15 Points: 1,446, Level: 15 Points: 1,446, Level: 15
Level up: 31%, 104 Points needed
Level up: 31% Level up: 31% Level up: 31%
Activity: 9%
Activity: 9% Activity: 9% Activity: 9%
Default GUIDE : Helicoiling / replacing exhaust manifold studs
by JSeaman 09-27-2009, 12:11 PM
Courtesy of Mark3 on mkiiisupra.net:
1st off i plugged the induction passages with tissue, then i drilled the holes out to 10mm, i think the correct size is 10.4mm but i didnt have that size drill, better too small than too big a hole though, lol
then get cutting new threads for heli coils to go into using plenty of lubricant, i found using an 8mm socket and 12" extension and ratchet fitted to the tap to turn it made it easier to keep it going in square!
which leaves you with this nice new thread
Next find your helicoils, i used M10x2d (2d means there length is twice the diameter, so 20mm long) find your helicoild insertion tool and screw them in
when completely in they look like this
i didnt bother to snap off the insertion lug as it wasnt in the way of the stud.
Next the studs, i used M10x1.5mm hi tensile steel rod and cut them at 65mm long.
File off any rough edges so makking it easy to bite into the new thread
i installed mine with permanent thread lock
the finished item, 6 more to do and its sorted.
and its on, and all 7 locking nuts with flat washers torqued to 32lbft, 3 more than normal to overcome the courser pitch of the thread.
dont forget to use plenty of lubricant, degreeser before thread lock and a tin of compressed air comes in handy too for clearing out the holes completely
Old 09-27-2009, 01:39 PM
suprarx7nut
300k NA Stock and Clean
Points: 11,693, Level: 46
Points: 11,693, Level: 46 Points: 11,693, Level: 46 Points: 11,693, Level: 46
Level up: 79%, 107 Points needed
Level up: 79% Level up: 79% Level up: 79%
Activity: 29%
Activity: 29% Activity: 29% Activity: 29%
suprarx7nut's Avatar
Spent time on board: 1 Month, 0 Weeks, 1 Day and 0:29:14 Hours
Re: GUIDE : Helicoiling / replacing exhaust manifold studs
Good info. As a personal addition, double check that your tap is the correct size, regardless of whether it came in a kit or not. The tap must be a helicoiling tap. A regular tap does NOT work with helicoils.
suprarx7nut is offline   Reply With Quote
Old 09-27-2009, 05:29 PM
Points: 95,793, Level: 100
Points: 95,793, Level: 100 Points: 95,793, Level: 100 Points: 95,793, Level: 100
Level up: 0%, 0 Points needed
Level up: 0% Level up: 0% Level up: 0%
Activity: 99%
Activity: 99% Activity: 99% Activity: 99%
IJ.'s Avatar
2 "issues" I can see
1: Hi tensile is neither needed nor desirable for the studs as something ductile is better able to cope with the heat and expansion.
2: Loctite in this area is useless as to remove a Loctited part you use heat.
IJ. is offline   Reply With Quote
Old 09-29-2009, 08:32 AM
mark3
Lurker
Points: 1,632, Level: 16
Points: 1,632, Level: 16 Points: 1,632, Level: 16 Points: 1,632, Level: 16
Level up: 41%, 118 Points needed
Level up: 41% Level up: 41% Level up: 41%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
mark3's Avatar
Spent time on board: 6:30:19 Hours
i was under the impresion the stock Toyota studs where hi tensile, so i followed suit! and if you ever intend to remove them at a later date, say after a few 1000 miles, mild steel will just sheer off when the nut rusts onto the stud.
as far as the thread lock goes it was more to stop the studs turning into the head when nuts tighted, just incase!!
mark3 is offline   Reply With Quote
Old 10-06-2009, 04:50 AM
SwedishMeatball
Lurker
Points: 863, Level: 11
Points: 863, Level: 11 Points: 863, Level: 11 Points: 863, Level: 11
Level up: 43%, 87 Points needed
Level up: 43% Level up: 43% Level up: 43%
Activity: 1%
Activity: 1% Activity: 1% Activity: 1%
SwedishMeatball's Avatar
Spent time on board: 2 Days and 6:13:03 Hours
really nice guide.. but is it possible to do without removing the head from the car?
Cause ive had a BHG last year and just now my threads r giving up, not in the mood for removing it
SwedishMeatball is offline   Reply With Quote
Reply
Bookmarks
Tags
exhaust, guide, helicoiling, manifold, replacing, studs
Article Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Articles
Article Author Forum Replies Last Post
Stripped exhaust manifold studs..... supraGhost 7M-GTE Engine Technical Discussion 20 08-03-2009 12:53 PM
replacing hub studs need help! MA717MGTE General MKIII Discussion 9 09-24-2007 05:48 AM
Replacing Exhaust Manifold CBLEGUY 7M-GTE Engine Technical Discussion 5 01-08-2007 03:34 PM
Exhaust manifold studs BuiltMK3 7M-GTE Engine Technical Discussion 10 03-11-2006 05:12 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Supramania hosting, software and bandwith brought to you by a grant from Supracentral.com, ad revenue and from member donations. Thank You!
