With the recent surface of some topics regarding E-fans, and the Tari (Thats plural Tarus) Fan, I had been asked to do a write up from a couple members on my install. So here we Go:
BASIC INFORMATION REGARDING THE E-FANS:
Flow Ratings:
~2800 CFM Low
~3800-4200 CFM High
AMP Draw:
130 during initial start up and settles at ~40 amps
(DISCLAIMER: I am not recommending, nor not not recommending that you would want to consider an Alt upgrade, Mine was already upgraded)
Came in:
late 80's early/mid 90's Ford 3.8L V6 Engines
MATERIALS LIST:
1 Ford E-FAN
2 75 AMP Relays
2 Toggle Switches
1 Radiator Fan Switch 179*F-170*F, from a 1980 VW Rabbit (PN VWW022212)
18 AWG Wire
10-12 AWG Wire
Spade Female Terminals 3x 10AWG, 12 18 AWG
First:
You need to get ahold of a Ford E-fan out of ANY 3.8L V6 from the Late 80's Early 90's. However depending on the Car the Shroud and sometimes the fan blade changes. Mine came from a 93 Tarus SHO, and it has great coverage and fan size was perfect.
Second:
Get it home clean it up. Check the wiring. Make sure it operates fine. These have a DUAL Speed setting. Ground + 2nd Wire = High, Ground +3rd wire= Low. Ground + both wires = Medium (no garuntee this is good for it)
Third:
After you've verified its good. Its time to check fitment. I had to shave approx 1/4" on the bottom center to provide clearance for my Crank Pulley, I'm however Running a 3 row Haste Aluminum Radiator.
Also I had to cut a section of the fines out on the right hand side where the water pump pulley interfered w/ it.
Fourth:
This is your choice: I chose to replace the wiring coming out of the fan, Mostly because they cut my pigtail before the connector. So I disconnected the stock wiring from the fan ON THE MOTOR (not the harness) All you need are 3 size 12 AWG Female Spade Terminals set up w/ approx 2 feet of 10-12 AWG wire. Crimp/solder/shrinkwrap.
Fifth:
Mount the fan on the Radiator. check clearances and coverage. I simply took some sheet metal and a vice and bent mine to shape drilled 2 holes in each side, and used the stock mounting holes for one side of the bracket. Then I drilled a hole in the fan on the other side of the bracket and used a nut and bolt to secure the fan to bracket.
Now its a simple drop in unit. Check fitment and pull it out for wiring
WIRING:
okay here comes the more challenging aspect (not really) . I'm leaving this brief as this will be a loose guide for you to pick and choose from.
I currently have 2 different circuits running my E-Fan. A High-Speed and Low-Speed circuit.
The way they are setup provides an automatic function for temperature control that I do NOT have to monitor. W/ the option of a High setting for heavier driving. To Activate the High setting, I simply turn off my low switch, and turn on the High-switch (this prevents the circuit from activating and putting me on the MED setting)
The High-Speed circuit, is a simple switch wired to the relay. Mounted on my drivers side above my dimmer switch.
This allows me the option of pulling that extra air, after hard pulls, stop and go traffic or hot days. W/ the amp draw of this fan its not something you want/need to have running continuously.
Low-Speed circuit;
little more complex, I did some research on fan controller options, and all those high-tech gizmos. I didn't like the push through probe styles that you just set in the fins of your radiator, you don't get a true reading, and its just another unit to wire up. I did some digging and found that 1980 VW Rabbit, had a temp switch which activates at 179, and shuts off at 170. PERFECT!!
(NOTE: there are 2 others that look exactly the same 1 w/ higher temps (approx 10* higher) and 1 w/ lower temps (approx 10* lower) I recommend this one for optimum operating temps. )
I took this Radiator temp switch and Drilled and Tapped a hole on the underside of my Thermostat housing elbow. It was the only optimum location IMO and this way you're getting TRUE block temperatures.
I put teflon tape and Coated the sides w/ FIPG to create a total seal as I was unsure and really didn't want to take this piece off again.
Next I mounted my 2 75 AMP relays where my battery used to be behind the headlight. I Put a white stripe on them to annotate which one was what circuit.
From there I just wired everything together,
Both relays being Powered directly from my battery junction box under the hood.
Both Switches pulling power from a fused location under my dash, running out my firewall, up to relay(high)/Temp switch(low) and then grounding in the same place as my Fan.
Here's a Diagram of the wiring I used, and cleaned up a little for public appearance.
Hope this Provides some insite and help for everyone. I've been running this setup for 2 w/ zero issues, Temps are spot on and as soon as the low setting comes on it starts dropping. If I hit the High Setting, it plummets QUICK. ENJOY!
