Living the dream...
Points: 89,320, Level: 100 |
Level up: 0%, 0 Points needed |
Wiring your MKIII Supra around the Lamp Failure Box
This will allow you re-wire your 1987 MKIII Supra so that you can throw away your lamp failure box which causes your brake lights to not work if it goes bad.
If the light on your dash that looks like your car is farting comes on, it means there is a problem with one or more of your lights in the rear assembly. First of all, check all of your lights to see if anything is not lighting up correctly. If they all check out, then double-check the bulbs to make sure they are intact. If you still see no problem, then you probably have a faulty lamp failure box.
I’ve been told by reliable sources that the soldering done by Toyota was pretty lousy. Over time, these boxes tend to fail - rendering your brake lights or other rear lights inoperable. The first option to fix this is as follows:
#1 – Remove the lamp failure box. It can be accessed through the driver’s side rear light assemble in your hatch. Pop off the access panel, and you’ll see a little, yellow, square, plastic box underneath the light assembly. It is attached to the body by a small bolt. Remove the bolt, and you can pull the box up for inspection. Unplug the pin connector, and take it apart. I used a flat-head screwdriver to pry one side out. After that, it just came right apart. Inside, there is a small circuit board. You may see a solder that has become weak and broken over time. If so, re-solder it carefully and try plugging the box back in. If it does not fix the problem, save yourself a headache and move to method number two.
#2 – Remove the lamp failure box (LFB). Throw it as far into nearby woods as possible. Retrieve your wiring tools (strippers, crimpers, and connectors). The most important thing to remember about this process is that you will not be cutting any wires that go directly into the light assembly (off-white connector). You will only be cutting wires that go to the LFB (blue connector). Cut the green w/white wire and the red w/blue wire. Splice them together. Now cut the solid green wire and splice it to the green w/red wire. Once again, none of these should be going to the light assembly. Only the ones that went to the LFB connector are spliced. There may be wires of the same colors going to the light assembly (off-white connector), but they are NOT the right wires!!
At this point, you should have fully functioning rear lights and no light on the dashboard. The only downside is that your vehicle will no longer notify you when you have a rear light out. Hey, we survived for how long on the roads without those boxes? I’m sure we can do it again now.
