+ Reply to Thread
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Supra Head Flow (5M,7M,1JZ,2JZGE,2JZGTE)
  1. #21
    I-6 Turbo Specialist
    truckman1966's Avatar
    Join Date
    Oct 2008
    Location
    Bellingham, WA
    Posts
    13
    Default Re: Supra Head Flow (5M,7M,1JZ,2JZGE,2JZGTE)
    this only referring to port flow, what about advantages on 1.5JZ because of combustion chamber shape/size?
  2. #22
    Fantastic post and effort! I came across this thread while searching google.
    I have the head off my IS as I'm swapping it over to a GTE block, and I noticed that the exhaust ports are quite different on cylinders 1,2, and 3 (cylinders 4,5,6 look like matched pair to cylinders 1,2,3). With the manifold off, and looking straight into the exhaust port of cylinders 1 all you see is one exhaust valve that has a short run right to the exit....while the other exhaust valve is around the bend and partly swipes across the other valve on it's way out. The air has to travel further and it looks like it causes some turbulence on its way out (based on pattern of build up in the port). Cylinders 2 and 5 are more centered, cylinders 3 and 6 look like a mild version of the problem in cylinders 1,4. I wasn't planning to port the head while it's off, but I'm feeling like I should try to match each cylinder better.
    Sooo, I was wondering if flow data existed for cylinders 1-3 on the exhaust side of a 2JZ-GE head, or even the GTE head. It seems difficult to believe they would all flow the same. Also, I recall Larry Windermere (Endyn) stated that even the GTE head was a challenge to get all ports to flow the same.
    Thanks
  3. #23
    Junior Member
    MK3Hitman21's Avatar
    Join Date
    Mar 2011
    Location
    Fontana, California
    Posts
    81
    Gamer IDs
    PSN ID: hitman2021
    1jz was the best designed head for a starting point so of course the 2j will flow better it has the blue print of 1jz design. as i'm a beast athlete my son will be better..
    I hope your behind me once my wheel flew off.
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Links monetized by VigLink
