Bryan T.
-87 supra- 7m on methanol, gt5591, GM Pg, 4 link, ford 9", 30"x14" drag radials- Coming no time soon...
-88 supra- 10.55 @ 126.77- 7m powered (long gone)
-66 chevelle - 05 Cummins dually
different head, different problems to address, no cam/crank sensors, distributor, ports different. Its like the difference in a 5m-ge and a 7m-gte... I personally think it should be another list, as it takes a little more work to make a GE make big power with a completely different list of obstacles to overcome.
Sorry dude. Not making another list. They aren't even filled up as they are. Then I'll have to make a 1.5jz list, and then a 7mge list, and then a turbos under 61mm list, and then a slipping clutch list, etc. You get the point.
Bryan T.
MKIII: MoTeC, Tilton, 7M Powered, 9 sec street car. Tuned by: John Reed Racing
Canada's fastest & quickest Street Supra
1015 RWHP 7M
105 WHP 600 F4i
A 1JZ strains to make power like a dandelion struggles to be a flower.
Dyno'd Tuesday with the single turbo. Stock ECU can't handle the power, so I'm going standalone. I did a pull of 393 RWHP and 340 RWTQ, but the graph went nuts at 6k. So I have it set at 350 RWHP right now at 16 lbs of boost. Mods are: 1JZ, Driftmotion 60-1 .70 A/R twin scroll turbo, full Garrett internals, DM twin scroll manifold, 3" turbo-back exhaust, SAFC NEO, JDM 2J 440cc injectors, CAI, FMIC, 2.5" IC piping.
Project Clean 87 Build Thread
http://www.supramania.com/forums/showthread.php?t=40754
Engine built and tuned by Bill Bowering @ Independent Speed Shop in Langley, B.C.
http://indy-speed.com/
Need more MKII's on that list
HKS twins
104*F
19psi
94 MKIV 6sp Single 726rwhp
89 MKIII 7MGTE unmolested
82 MKII 1JZ 451RWHP
06 350Z
OK need to throw my hat into the ring here
7M-GTE, 35R, Motec M800, UNPORTED HEAD, HKS Cams, Greddy Intercooler, Stock in take manifold, Turbo A throttle body.
The conversion comes out to 540rwhp.
Aiming for 600 on the fateful day its back in one piece
Dan
89 3.0GT Limited
JDM MA-70 3.0GT Limited Build
HKS_TRD on GTEPowered.com
ONE SUPRA CAN MAKE A DIFFERENCE
my dynopic from today. This is rwhp with a setup of mapecu2, gt35r, rc550, mid-ported head. This effect is at 18psi and my boost where very inconsistant so the curve is not representative for the whole rpm-scale.
What's the big dip @ 140kph?
thats my boost going down to 13psi.. I had trouble keeping it stable. The guy at the dyno said that it could bee because the solenid is getting two hot. Iam going to re-locate it and se if it makes a difference. They had a car yesterday with simular problem, that got much more stable boost after cooling down the solenoid.
Bookmarks
