Edit start: AOL pictures gone.
Long runner manifold:
Short runner, AC delete, MKIII:
Short Runner, AC delete, MKII:
Short runner with AC:
2JZ-GTE Short runner:
Edit end.
As some of you may know, I have been making these manifolds for at least 3 years now. Been running the long runner style on my car for longer than that. Thought I formally post here and see how it goes. Anyways, below are pictures of both styles that I make. The long runner style flows ~280cfm per runner. I need an upper plenum and lower alternator bracket cores for this one. It is priced at $600.00 with brackets, plus shipping.
Shown here with a Lexus 400 TB.
Inside the long runner plenum, before cleaning the welds inside:
One on my car with an Accufab TB.
The other style is the short runner/big plenum style that flows over 300 cfm per runner. I need a lower manifold as a core for this one, and upper plenum if you want the Idle Speed Control provision. It is priced at $950.00 including a one piece billet aluminum alternator bracket, plus shipping.
Here's one I made for our friend in Denmark.
After hand porting.
Bottom view if you prefer the ISC provision and vacuum ports to be hidden.
As you can see, I have made them with or without provisions for ISC, cold start injector and flanged for just about any throttle body you prefer to use. The long runner style retains the A/C system while the short runner style doesn’t, at least until I design another alternator bracket. I can also provide a modified aftermarket throttle cable for the cost of just the cable but need your stock one for it. If interested, or for any questions, please send an e-mail to ronram7728@aol.com
On very rare occassions (because of my schedule and workload) I can also make a turbo header.
Too many pictures on this post already so if you are interested, please check the links below.
http://supras.dagazgroup.com/supras/ronr/
http://www.cardomain.com/ride/463369/5
Update, 6-18-06
Alternator BELT Part numbers:
For long runner: Dayco polycog, 5050480
For short runner: Goodyear Gatorback, 4050450
Update, 6-23-06
Making the throttle cable:
Page 5 of this thread, post #43
Update, 7-23-08
ordering info
Here's what I need for a manifold order:
1. long runner order, upper intake manifold (stripped of all accessories, fittings, nuts and bolts)
short runner order, both upper and lower manifolds (stripped of all accessories, fittings, nuts and bolts)
2. lower alternator bracket (long runner manifold only)
3. throttle body you are using
4. deposit of 250 dollars for long runner
and 500 for short runner (can be paypal'ed, please PM)
5. a piece of paper with the following info:
full name and address
sm username
list of parts you sent me
style manifold you are ordering
provisions needed; vac ports, ISC, CSI, etc.
My shipping address is:
Please pm for address.
Not sure if you know yet but Don Culbertson sold her to me a few months ago.
Bookmarks
