Page 146 of 146 FirstFirst ... 4696136142143144145146
Results 1,451 to 1,458 of 1458
Thread: Project Clean 87
  1. #1451
    Happy as hell :D
    honestabe's Avatar
    Join Date
    Jan 2006
    Location
    Mount Vernon, WA, USA
    Posts
    3,813
    Default Re: Project Clean 87
    Quote Originally Posted by Piratetip View Post
    Hah, I have you beat!
    Pretty sure I installed mine in...2007
    Either way the memory is going fast...
    Look an old photo I dug up!
    Yep they definitely came with the ST bars.
    I installed zerk fittings as well.Attachment 79447
    It could have been late 2007... To be fair this Supra was a rolling shell in March 2007, I drove it home from Camp Pendleton to Portland in October 2007.
  2. #1452
    Far From Maddening Crowds
    Piratetip's Avatar
    Join Date
    Dec 2005
    Location
    MKE, WI
    Posts
    747
    Nice.
    I bought mine in July of 2003
    I rebuild / upgrade Supra Differentials - PM me for more information.
    1 Piece Driveshaft Information
    Critical Speed Calculator
  3. #1453
    Regular Member
    Join Date
    Apr 2005
    Location
    Alpharetta, GA
    Posts
    339
    Quote Originally Posted by honestabe View Post
    Did you consider the routing / path of your exhaust piping? The location or lowness of the pump and filters may likely cause an interference.
    My 4" barely clears the bottom of the subframe tucked into the rounded area cutout, but still scrapes occasionally on speed bumps, driveways, road imperfections, etc..
  4. #1454
    Happy as hell :D
    honestabe's Avatar
    Join Date
    Jan 2006
    Location
    Posts
    3,813
    Quote Originally Posted by BlackDevilSupra View Post
    This is a setup I got from my buddy that was in an un-driven project. I am sure I will have to do some modification once I go to put my exhaust back on. I do plan on building a skid plate for the rear though.
    Also, I only have a 3" exhaust so that helps.
  5. #1455
    Happy as hell :D
    honestabe's Avatar
    Join Date
    Jan 2006
    Location
    Posts
    3,813
    Quick poll, should I leave my gas tank black or accent it by painting it gunmetal to match my rims and trim
  6. #1456
    Happy as hell :D
    honestabe's Avatar
    Join Date
    Jan 2006
    Location
    Posts
    3,813
    Gas tank return line fitting JB Welded seal up any micro holes my welding missed. Once cured the tank will be sanded to smooth out imperfections in the JB Weld then painted semi-flat black.
    Mock hinge built from an old motorcycle fairing (same ABS plastic and roughly the same thickness). Added a 2nd layer to thicken up the area where the hinge is sunk in. On the real console the 2nd layer will run the whole length of the console.  I heated up the hinge to melt it into the plastic, then added a layer of screen mesh over it to reinforce the hinge.  The black you see is the ABS filler rod I used, just like TIG welding.
    This finished console will be body worked to smooth perfection then covered with fabric. This of course is just a proof of concept, no need to make show quality.
  7. #1457
    Happy as hell :D
    honestabe's Avatar
    Join Date
    Jan 2006
    Location
    Posts
    3,813
    Gap no more! On the real thing I will have to create a cavity for the hinge so it sits sealed.
  8. #1458
    Happy as hell :D
    honestabe's Avatar
    Join Date
    Jan 2006
    Location
    Posts
    3,813
    A little progress today. Got the gas tank painted, trimmed the vertical center console piece and removed the vinyl wrap. I forgot about how the console was shaped so I am going to have to use the stock console as my template. I will need to construct it out of several pieces more than planned, but plastic is fairly easy to bend and weld so it shouldn't be an issue.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
