Page 35 of 40 FirstFirst ... 25313233343536373839 ... LastLast
Results 341 to 350 of 400
Thread: Bolt on Big Brake Kit For around 300$.
  1. #341
    Junior Member
    Join Date
    Dec 2013
    Location
    MS
    Posts
    57
    Default Bolt on Big Brake Kit For around 300$.
    Quote Originally Posted by MarkIII4Me View Post
    Calipers came as pictured. All I did was apply the red vinyl stickers.
    I tried stealing part numbers from your pictures but couldn't see all of them. Would you mind posting part numbers (if you have them) for what you have pictured?
    If those part numbers have already been posted somewhere here, I apologize. I've been trying to keep up with this thread though and don't think I've seen them anywhere. Thanks!
    1989 Turbo Supra, White Pkg - Build In Process
    7M-GTE w/stock turbo | Auto | Divorced/Recirculated Downpipe | Tanabe Touring Exhaust | DriftMotion Intercooler Kit
    Tokico Illuminas with H&R Springs | 18" CCW Knockoffs | waiting to be reassembled...
    2016 Tundra CrewMax TRD Pro
    TRD Intake | LED DRL/Fog Light Upgrade | Predator Pro Steps | Corsa Exhaust
    BFG A/TKO2 285/65R18 | OEM Audio+ | Camlocker | DIY Auto Headlights
    2009 Tundra D-Cab TRD Sport
    Lowered, supercharged and SOLD
    2004 4Runner V8 4WD - SOLD
  2. #342
    Project OVERKILL!!!
    MarkIII4Me's Avatar
    Join Date
    Apr 2005
    Location
    Charleston, SC
    Posts
    1,218
    Default Re: Bolt on Big Brake Kit For around 300$.
    Quote Originally Posted by Joe__G View Post
    I tried stealing part numbers from your pictures but couldn't see all of them. Would you mind posting part numbers (if you have them) for what you have pictured? If those part numbers have already been posted somewhere here, I apologize. I've been trying to keep up with this thread though and don't think I've seen them anywhere. Thanks!
    Sheesh! I gotta do everything around here.
    Rotors: OE# 164 421 13 12 / Brembo# 09.R104.11 (rotor vanes are non-directional)
    Pads: Brembo# P50041N
    Caliper:LEFT - OE# 001 420 82 83 WBR# 11-00861 / RIGHT - OE# 001 420 83 83 WBR# 11-00859
    Centering Ring: 67.1mm to 60.1mm aluminum rings (https://www.amazon.com/gp/aw/d/B01JN...236_SY340_QL65)
    Lines: PLENTY OF BRANDS TO CHOOSE FROM. ANY MK3 LINES WILL WORK.
    Mounting Bolts: 124 421 05 71 Qty:4
    WASHERS: 4 roughly 3MM thick M12 WASHERS. (Head bolt washers will work, but all are not created equal. Many vehicles use cheapo metal washers (like older Jettas). Others use M10 washers. I had some old E36 washers laying around that I drilled out to M12. Which was a PITA!)
  3. #343
    Junior Member
    Join Date
    Dec 2013
    Location
    MS
    Posts
    57
    That's awesome man, thanks!
  4. #344
    Project OVERKILL!!!
    MarkIII4Me's Avatar
    Join Date
    Apr 2005
    Location
    Charleston, SC
    Posts
    1,218
    I finally finished up the brakes. I wasn't going into the New Year with the brakes still apart. They look sweet! Once I can get someone to help me bleed them, then I can actually drive and see how different it feels.
    I sanded, rebuilt and painted the rears until I find a deal on the Evo calipers. Considering they were rusted and ceased when I started this, I'm very happy with the end result.
  5. #345
    Far From Maddening Crowds
    Piratetip's Avatar
    Join Date
    Dec 2005
    Location
    MKE, WI
    Posts
    732
    Nice.
    Looking forward to getting a set of these.
    1 Piece Driveshaft Information
    Critical Speed Calculator
  6. #346
    Regular Member
    slowma70's Avatar
    Join Date
    May 2011
    Location
    Orlando,FL
    Posts
    293
    has anyone had issues with the heat and plastic hub rings?
    im running hubcentric spacers and believe the hub rings will interfere with them or do they sit flush with the rotor?
  7. #347
    Project OVERKILL!!!
    MarkIII4Me's Avatar
    Join Date
    Apr 2005
    Location
    Charleston, SC
    Posts
    1,218
    Look at the pics I posted above. The aluminum hub rings I used do not sit flush with the rotor.
  8. #348
    tested
    ibcrazee's Avatar
    Join Date
    Jan 2010
    Location
    south of I-10
    Posts
    26
    you'll have to trim them so they do sit flush. done.
    red toys
    84 L-type
    89 turbo
    05 srt-10 ram
    85 gmc shortbox - all sho-no go
  9. #349
    Supramania Regular
    yhatzee89's Avatar
    Join Date
    Aug 2012
    Location
    Montgomery, AL
    Posts
    930
    did you have to cut the dust shield?
    "I got 99 problems but a 7M ain't one!"
    "MKIII Supras, turning men into mechanics since 86.5"
  10. #350
    Lurker
    Join Date
    Jun 2012
    Location
    New zealand
    Posts
    Quote Originally Posted by yhatzee89 View Post
    It tells you in the first post to either cut or bend the dust shield out of the way
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
