+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Boost leak?
  1. #1
    Regular Member
    mk3supra's Avatar
    Join Date
    Apr 2005
    Location
    Decatur, IL
    Posts
    231
    Gamer IDs
    Gamertag: YoungMuhla
    Default Boost leak?
    iv just completed my engine swap and now whenever the the turbo goes to spool up it bogs down and doesnt produce any power, iv looked for boost leaks couldnt find anything. i also read that at idle you sould have a vaccum of 20 psi and mines only around 13. Iv shimmed the wastegate and when it spools up it reads about 10 psi, is there a way the wastgate could be stuck open? im completely lost and would sure appreciate help. thanks in advance
    Jason
  2. #2
    i hate this car
    sleepersupra's Avatar
    Join Date
    Nov 2005
    Location
    Broken Arrow, Ok
    Posts
    311
    Default Re: Boost leak?
    did you check timing, just a thought
    2004 WRB STi
  3. #3
    Supramania Regular
    antman's Avatar
    Join Date
    Apr 2005
    Location
    TN
    Posts
    632
    vaccum isn't read in psi, and not all cars will read that much. it depends on condition of your engine and desity of air. i acually have never seen a supra pull 20 in.hg of vaccum at idle.
  4. #4
    Single, and lovin' it!!
    The Reaper's Avatar
    Join Date
    Jan 2006
    Location
    Florida
    Posts
    1,909
    come to my house i'll show ya one
  5. #5
    Supramania Regular
    antman's Avatar
    Join Date
    Apr 2005
    Location
    TN
    Posts
    632
    being right at sea level probably makes a difference, but if you didn't live so damn far away i would take you up on that. always wanted to see florida.
    "Failure is the opportunity to begin again more intelligently."- Henry Ford
  6. #6
    Living the dream...
    Supracentral's Avatar
    Join Date
    Dec 1969
    Location
    Woodstock, GA USA
    Posts
    10,424
    Blog Entries
    Gamer IDs
    Gamertag: o13102 Steam ID: supracentral
    Quote Originally Posted by antman
    All of mine have, unless there was an intake manifold leak or damaged rings/valves.
    As a matter of fact a vac gauge is one hell of a diagnostic tool that many people overlook.
    Here are some of the things a vac gauge can tell you:
    • gauge reading steady 17-22 in Hg indicates normal engine in good condition.
    • gauge reading low but steady indicates late ignition or valve timing, low compression, stuck throttle valve, leaking manifold gasket, etc..
    • gauge reading steady but dropping regularly indicates burnt valve or improper valve clearance.
    • gauge reading dropping gradually at idle indicates obstructed exhaust.
    • gauge reading slowly dropping to zero as engine speeds up indicates obtructed exhaust.
    • gauge reading fluctuating between 15 and 20 in Hg at idle indicates stuck valve or ignition miss.
    • gauge reading drifting indicates a minor intake leak at the manifold.
    • gauge reading fluctuating as engine speed increases indicates weak valve springs, worn valve stem guides.
    • gauge reading vibrating excessively at idle but steady as engine speeds up indicates worn valve guides.
    • gauge reading vibrating excessively at all speeds (when not under boost) indicates a blown head gasket.
    • healthy decelerating engine reading should jump to 21 thru 27 in Hg as open throttle released.
    These rules hold true for just about all 4 stroke gasoline engines, regardless of manufacturer or configuration (I4, I6, V6, V8, etc..)
    >>I will no longer respond to tech questions via PM. If you have a question, put it on the forum so everyone benefits from the answer.<<
    Mike "Nightmare" Donohue
    "Stupidity is permanent and often fatal, Ignorance is curable with education..." -- Me
    Frequently Asked Supra Questions: Rod Knock - HKS WG Springs - Injector Sizing - What is A/R? - Buy a TSRM - HKS HG FAQ - AFPR - Machinist - Overboring - Vac Diags - Motor Oil - Seafoam - Spark Plugs - Air Filters - V6 vs. I6 - Solder vs. Crimp Connectors - How to make power - Stroker Motors - Unreliable 7M's? - Piston Slap - Home made race fuel - Budgeting a build - Tuning and Vf
    Frequently Asked Forum Questions: What will get you banned? - Posting and you - Ideals - Membership - Usage - BBCode - Smiles - Scammers - How to make thumbnails - History
    Other Bullshit: Global Warming - Global Warming Facts - Religion & Politics - Collectivism -War On Drugs - Founding fathers were Diests - Religion and The Constitution - Size of the Federal Gov't - Canadian Healthcare - Socialists -European opinons of the U.S. - U.S. standard of living - U.S. - the worlds best customer - Modern Education - A Government created problem - Environmentalism is a big problem - Taxes - Socialism death toll - Can't afford healthcare? - I am my own god - Atlas will shrug - Not paying a "fair share"? - Income taxes are not a necessity - How to succeed, a 60 second lesson - How a liberal approaches facts. - Who is responsible for the financial crisis? - You asked for it. - Understanding Women - Understanding Men - Personal question? Answer is probably here. - Why I carry a gun. - Fuck the rich? - US Politics in a nutshell - The one principle that matters - Why anarchy is a fools errand - This is what it feels like to be me. - Living an awesome life - The crash is coming
    Since the beginning of recorded history, which is defined by the invention of writing by the Sumerians around 6,000 years ago, historians have cataloged over 3700 supernatural beings, of which 2870 can be considered deities. I don’t believe in 2,870 gods, and you don’t believe in 2,869. You're nearly as much of an Atheist as I am.
    Government is a good thing: Through correct principles, I govern myself.
    Public Notice: Contrary to popular belief, I do not consider everybody who disagrees with me to have brain damage. Those who don't have brain damage will be able to explain and justify their points of view in a logically defensible way. That's the way the Rational Discourse game is played. If you don't want to play the Rational Discourse Game, don't expect anybody (least of all me) to take you seriously.
    Quote Originally Posted by jetjock View Post
    If you drive like that on public streets I won't be disappointed if, as long as you were alone, they one day hose you out of a twisted mass of smoking metal into a bucket and melt what's left of your car down into tuna cans.
  7. #7
    The Reaper's Avatar
    Join Date
    Jan 2006
    Location
    Florida
    Posts
    1,909
    wow thats some damn good info!!!!!
    and yea florida is nice until the summer. i have no A/C in my car cause the line blew and im busy buying performance shit rather than 50-80 bucks for a hose. LOL if you dont have A/C in florida yur a dumbass so i am a dumbass
  8. #8
    i hate this car
    Join Date
    Nov 2005
    Location
    Broken Arrow, Ok
    Posts
    311
    Quote Originally Posted by Supracentral
    that should be a sticky cause that is some of the greatest info i've seen in a while....never ceases to amaze me
  9. #9
    92 teal-wn turbo
    supramike7m's Avatar
    Join Date
    Jan 2006
    Location
    prescott, Arizona
    Posts
    759
    yes stickie this definatly ^^^^^
  10. #10
    I was speeding?!? NO WAY!
    fatality's Avatar
    Join Date
    Mar 2006
    Location
    Houston
    Posts
    51
    Quote Originally Posted by Seven M
    Ditto!
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Links monetized by VigLink
