+ Reply to Thread
Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
Thread: 440s+afpr+ Lexus afm
  1. #41
    Supramania Regular
    Turbo Habanero's Avatar
    Join Date
    Apr 2009
    Location
    Tucson,AZ
    Posts
    4,143
    Gamer IDs
    Gamertag: Turbo Habanero
    Default Re: 440s+afpr+ Lexus afm
    Finally caught up to this thread......
    My brain hurts real bad !!!!
    -Jordan
    My build thread Furious 7M owner who gave up JUST CLICK ON IT
    Quote Originally Posted by Dylan JZ View Post
    This one wont have the infamous 'M' for malfunction, so I think he'll be just fine
    Quote Originally Posted by IJ. View Post
    Been replaced with a "J" though
    (for Jordan so it's gonna be a close thing)
    Youtube Account - Turbo habanero's youtube Channel Clicky
  2. #42
    Supramania Elite
    jetjock's Avatar
    Join Date
    Jul 2005
    Location
    Posts
    8,434
    Blog Entries
    Tell me about it. It's sad to see this much fail in the Tech Section.
    In memory of Rimma Kiselitsa
  3. #43
    Established 1994
    Nick M's Avatar
    Join Date
    Sep 2005
    Location
    Posts
    7,650
    The reason air temp is monitored is so the PCM can determine a cold start. When the intake air and coolant are the same, the PCM knows it is a cold start, and the correction factor for running is applied. You can see this with your idle speed. It goes down as coolant temps rise. Adding a resistor to the IAT might make the PCM think the engine is really warm with the large difference between coolant and air. We would have to see what all is decoded in 3p's thread.
    Have you loosened Orion's belt yet?
    The opposite of right is both left and wrong.
  4. #44
    Kurt is FTMFW x2!!!!
    shaeff's Avatar
    Join Date
    Mar 2005
    Location
    Tivoli, NY
    Posts
    10,605
    If you want to read up on why each part is supposed to be used, take a good long look at this article. Once you've finished reading it, go ahead and read it again. There are always people who do things differently but with varying amounts of both success and utter failure. If you're new to the Supra game and don't have a firm understanding of why each part is highly recommended, I suggest you do it right or don't do it at all.
    Read this: http://rob.carlile.home.mchsi.com/lexus/lexus1.htm
    Quote Originally Posted by jetjock
    Big snike! She's ah big bugga!
    I was picturing Ian in his Crocodile Dundee hat and missing one snake skin boot. 10/10 for execution and hilarity!
    Quote Originally Posted by Stephen Crane
    A man said to the universe:
    "Sir I exist!"
    "However," replied the universe,
    "The fact has not created in me
    A sense of obligation."
    Srs bsns...Check your Diagnostic Trouble Codeswww.mkiiitech.com contributorwww.4cefed.comDEALING WITH THE "OLDSCHOOL" GUYS
  5. #45
    What would be a good stand alone or piggy back tuner to go with for these mods?
  6. #46
    Established 1994
    Nick M's Avatar
    Join Date
    Sep 2005
    Location
    Posts
    7,650
    Quote Originally Posted by 7m-gte 87 View Post
    Larger injectors.
  7. #47
    Quote Originally Posted by Nick M View Post
    Larger injectors.
    I mean what would be best to help tune the 550, lex maf, and more boost. Would I need to go with an aem ems?
  8. #48
    Supramania Regular
    Join Date
    Apr 2009
    Location
    Tucson,AZ
    Posts
    4,143
    Gamer IDs
    Best is up to opinion
    Stand alone AEM,pro efi ect...
    Then
    Maft pro
    Then
    Vpc with 550 chip and Apexi safc,nee ect...
    Or just a
    Apexi safc/neo
    -Jordan
  9. #49
    Established 1994
    Nick M's Avatar
    Join Date
    Sep 2005
    Location
    Posts
    7,650
    I have a T04E compressor. They are about 58mm in 57 trim. I would have to double check. Lex meter, 550's, no tuning aside from TCCS and it idles and runs perfect. The further the screw is turned in, the lower the overboost fuel cut. And the better it runs.
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Links monetized by VigLink
