Ok so my dumb ass over torqued my new tie rod end, where it connects to the spindle. The TSRM calls for like 36 ft-lbs, I took it to like 60+ and stretched the bolt so the hole for the cotter pin is way above the ridges of the castle nut. In other words, if I put the cotter through the hole in the bolt, there is nothing to keep the bolt from backing off on its own due to vibration. I ordered a new tie rod end, which is probably the best thing to do, right? Im guessing it would not be smart to leave it as is? Thanks for any advice.
Bookmarks
