Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: WRX STI vs 90 Supra 1jZ from a DIG!
  1. #11
    Supramania Regular
    Turbo Habanero's Avatar
    Join Date
    Apr 2009
    Location
    Tucson,AZ
    Posts
    4,230
    Default Re: WRX STI vs 90 Supra 1jZ from a DIG!
    If anyone wants to take a guess on what kind of power its making be our guest cause we are unsure
    Mods are
    1jz from a jza70 with mines ecu.
    Aeromotive AFPR
    Walbro 255
    Stock twins on 16psi dropping to 14psi
    Full 3inch exhaust
    Aluminum radiator and one huge electric fan.
    Vis carbon fiber hood
    Gutted from front seats back
    It's on a street radial from bridgestone 255/50r16 on the back Mk4 wheels
    3inch intake filter
    Turbo xs mbc
    Aftermarket decent size front mount with 2.5 inch pipes and hks bov
    -Jordan.
    My Personal Instagram @Built1jz and I Created a Page for all Mk3 owners @Supra_Addicts
    My build thread Furious 7M owner who gave up JUST CLICK ON IT
    Quote Originally Posted by Dylan JZ View Post
    This one wont have the infamous 'M' for malfunction, so I think he'll be just fine
    Quote Originally Posted by IJ. View Post
    Been replaced with a "J" though
    (for Jordan so it's gonna be a close thing)
    Youtube Account - Turbo habanero's youtube Channel Clicky
  2. #12
    Classifieds Moderator
    te72's Avatar
    Join Date
    Mar 2006
    Location
    WHYoming
    Posts
    6,605
    Quote Originally Posted by Turbo Habanero View Post
    Trying to figure out the power of this 1jz using this http://www.corral.net/tech/brakehp.html
    His best track time
    13.8 @ 106mph
    Now we just have to figure out the wieght.
    Car is a 1990 1jz stock twins
    Gutted only from the front seats back
    Mk4 16 inch wheels
    Aftermarket intercooler with 2.5 pipes
    R154 trans
    Targa top
    Stock front seats
    Any ideas on the wieght of this car with full fluids ???? Driver is 200lbs
    I would say that a 3600lb curb weight is realistic, give or take 50 lbs. Given his ET/trap speed, I get the idea that he spun a bit off the launch... he ran both faster, and slower than I did:
    What was his 60' on that run? And the rear end gear?
    -Brad
    1948 Chevrolet Fleetmaster, 1987 Supra Hardtop, 1989 Supra Targa, 1993 LS400, 1999 Miata
    Fast cars, loud guitars, a lot of hard work, patience, and crazy ideas. Yup, that about sums up my life.
    How to live with a Supra
  3. #13
    Lurker
    Join Date
    Jun 2012
    Location
    03431
    Posts
    29
    Well, I'm impressed anyways haha Good job....fuckin....subarus.....
  4. #14
    Supramania Regular
    Join Date
    Apr 2009
    Location
    Tucson,AZ
    Posts
    4,230
    Brad it was like a 2.2 60ft and a 3.73 gear
    -Jordan.
  5. #15
    te72's Avatar
    Join Date
    Mar 2006
    Location
    WHYoming
    Posts
    6,605
    About what I figured. Well, for comparison's sake, my car makes 320whp on 12psi, which is how that run posted was made. Could be a dozen factors on why he ran that time, but I would suspect he is probably near what I am, power wise.
    -Brad
  6. #16
    Supramania Regular
    87supraguy's Avatar
    Join Date
    Mar 2010
    Location
    Tucson, az
    Posts
    808
    Hey Jordan. Dan is down to race you at firebird on the 27th. it would be our race all over again. only difference is he has a stock clutch, better tires and it's a different driver.
    Moderator- azsupracentral.com
    Current status: 1jz (JZZ30), r154, stage 3 six puck ACT clutch, ACT PP, DM light weight Flywheel, aeromotive AFPR, AEM AFR guage and Wideband,
    BEING TORN DOWN FOR UPGRADES!!!!
    Proefi 128, 1JZ, R154, 1zz coils, 1200cc injectors, E85, dual 400lph walbros pumps, 2jz water pump, BC 272 cams, BC spring and retainers, Shimless buckets, Titan cam gears, Drewgo manifold, stage 3 six puck (sprung) ACT clutch and PP, DM light weight Flywheel, aeromotive AFPR, (real) HKS 50mm waste gate, AEM AFR Wideband, GT4294 1.01 a/r, SP QSV.... still collecting parts.
    parts still needed if you have them at a reasonable price pm me!!!!
    proefi related sensors and accesories
    Titan cam gears
    fuel lines (E85 compatible)
  7. #17
    Supramania Regular
    Join Date
    Apr 2009
    Location
    Tucson,AZ
    Posts
    4,230
    I can't make it on the 27th but I'm down eventually.
    -Jordan.
  8. #18
    Lurker
    Join Date
    Feb 2010
    Location
    AZ
    Posts
    24
    I wouldnt mind beating Dan with my stock twins better clutch and better tires.
  9. #19
    Supramania Regular
    Join Date
    Apr 2009
    Location
    Tucson,AZ
    Posts
    4,230
    Quote Originally Posted by lazer1100 View Post
    I think you can take it on the strip and lower rolls for sure.
    I still think I can take that setup if i can get my car running right.
    -Jordan.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
