Hey everyone, over the past several years we've gotten many requests for building brand new 7MGTE wiring harnesses since Toyota discontinued them. I'm happy to announce that we can build new 7MGTE harnesses for the '91 and '92 model engines with the newer style injectors, 02 sensors, knock sensors, grey 26/16/22 configuration ECU plugs etc. If you want to retrofit an older model 7MGTE with the newer style parts then this harness will work just fine. No core harness needed for model years '91 and '92, if you are using this in an older vehicle then you will need to either supply a core harness or pay the $300 core charge. (The core harness is ONLY used for the body connectors that plug into the fusebox and dash harness, everything on the engine is brand new). Turnaround time on these is normally 2-3 days. The harnesses are priced at $999.
Reply here or email us at sales@tweakdperformance.com with any questions.
-Joshua
Bookmarks
