+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Where to wire my aftermarket gauge for lighting?
  1. #1
    Junior Member
    SupraStoked's Avatar
    Join Date
    Apr 2012
    Location
    Milwaukee, Wisconsin, United States
    Posts
    81
    Default Where to wire my aftermarket gauge for lighting?
    I just finished installing a analog oil pressure gauge in the supra, but i want my gauge light to come on whenn i flick all the other dash lights/headlights on.
    where EXACTLY do i have to splice into to get that to happen?
    and the gauge just has a regular light bulb with two wires, one that says its for ground and the other for power..wouldnt i need a pos/neg flow of charge?
    Oh and yea, i put the gauge inside the gauge cluster.
  2. #2
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    38,653
    Default Re: Where to wire my aftermarket gauge for lighting?
    I'd wire it into the existing dash lights so it dims.
  3. #3
    Junior Member
    Join Date
    Apr 2012
    Location
    Posts
    81
    Quote Originally Posted by IJ. View Post
    yea i want to but how? the back of the gauges has that green motherboard thing and I wouldn't know how to try to get into that. I need like a specific point/pinon a connector/ or wire.
  4. #4
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    38,653
    Follow the Trace back from the Bulb holder, from memory it'll be a White wire with Green trace for power then hook the ground to the Brown (again from memory)
  5. #5
    Junior Member
    Join Date
    Apr 2012
    Location
    Posts
    81
    awesome thank you. just to clarify, when you said to hook the ground to the brown, are you talking about the brown contact part of the flexible motherboard where the old bulb would fit into?
  6. #6
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    38,653
    One side of the bulb holder will go back to a White/Green, the other to a Brown.
    (Might be Green/White) make sure to check it.
  7. #7
    Junior Member
    Join Date
    Apr 2012
    Location
    Posts
    81
    okay cool. sounds good thanks again!
  8. #8
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    38,653
    Welcome!
  9. #9
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    38,653
    Just checked it's White/Green and Green..
  10. #10
    Junior Member
    Join Date
    Apr 2012
    Location
    Posts
    81
    Default
    Ij.......you're the best!
    Sent from my LS670 using Tapatalk 2
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Links monetized by VigLink
