+ Reply to Thread
Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: Just picked up my first Supra
  1. #31
    Lurker
    bryan163's Avatar
    Join Date
    May 2012
    Location
    Connecticut
    Posts
    19
    Default Re: Just picked up my first Supra
    I found midnight blue in off the shelf form from duplicolor. Im planning on repainting the car before I drive it. I also dropped my block, head, and crank off at the machine shop today. I told them to dip it when they're done so it will be nice and clean for some engine enamel.
  2. #32
    324k and going strong
    suprarx7nut's Avatar
    Join Date
    Nov 2006
    Location
    Colorado
    Posts
    3,054
    Gamer IDs
    PSN ID: suprarx7nut
    Good choice on staying with the 7M, at least for now. The 7M reliability issues tend to be owner related and can mostly be avoided with proper care. The 2J can handle abuse like nobody's business, but the 7M isn't far off and is still a blast to drive.
  3. #33
    Lurker
    bryan163's Avatar
    Join Date
    May 2012
    Location
    Connecticut
    Posts
    19
    I figured i should become acquainted with the car as it is before i start making major changes. The machine shop called this morning to tell me that the head cant be machined because it is already at minimum thickness. I'm gonna pull the head thats in the car now to see if that one can be used. I might have to gut the thin head for parts and put them into the head thats on the car because the motor in the car died from being run out of oil.
  4. #34
    Beast
    boostrwd23's Avatar
    Join Date
    Apr 2012
    Location
    Wagontown, PA, United States
    Posts
    65
    that doesn't sound good, good luck with that.. I'm sticking with a stock 7m rebuild myself, waiting on parts to get it over to the machine shop
  5. #35
    Lurker
    bryan163's Avatar
    Join Date
    May 2012
    Location
    Connecticut
    Posts
    19
    Mine won't be too far from stock. Just want to fix the known weaknesses. I checked out the other head and the cams look good.i should have it out of the car tonight. Takea a lot longer to remove the head when its in the car than when its on the stand.lol I'll finish up tonight after work.
  6. #36
    Lurker
    bryan163's Avatar
    Join Date
    May 2012
    Location
    Connecticut
    Posts
    19
    update: Well its been about a month since I posted here, mainly because I hit a dead end when the machine shop condemned my 7M block. After doing a pass on the deck it was clear it had already been welded and needed more machining than it could take off still while maintaining minimum deck height. So my friend Chris who gave me the 7M was kind enough to give me a 2JZ-GE. It has high miles. Around 220k I think, but I'm just gonna run it for now because it runs good and doesn't smoke. I'm gonna grab a cheap ebay manifold and probably use a garrett turbo that I have at our shop. Also hoping to find a deal on a bell housing. I found some on ebay, but the prices were around $370-400
    Here's a the turbo I was thinking about using next to a CT26.
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Links monetized by VigLink
